Old 07-15-2014, 08:01 PM   #1
Parikh1234
Drives: Subaru BRZ Limited
OEM Driver Side Wheel Scraping?
I went to look at my car at the shop (getting it SC) and I noticed the driver side wheel well plastic (between the wheel and the front bumper) is all sorts of shredded. Do you guys have this problem? I didnt get to take a picture but ill post some up tomorrow. I just threw on a set of enkei RC-T4 in 17x8 +48 with 225/45 rubber, but the shop barely drove the car so I doubt it was from those. Thanks!
Parikh1234 is offline   Reply With Quote
Old 07-15-2014, 09:56 PM   #2
Ubersuber
Drives: BRZ Pearl White
That offset sounds wrong which could chew up those wheel well liners pretty quick.
Ubersuber is offline   Reply With Quote
Old 07-16-2014, 09:42 AM   #3
Parikh1234
Well, this must have happened before I put the new wheels on there. Also the offset is the same as the stock offset, its just that the wheel is .5" wider.
There were no marks on the new tire /wheel combo. Ill check the old ones.
Old 07-16-2014, 11:09 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
pics?
Old 07-16-2014, 11:33 AM   #5
wheelhaus
wheelhaus's Avatar
Put the wheel at full right lock and check if anything is close to rubbing. Are you lowered? I have the stock wheels with a 20mm spacer and they don't rub, so aftermarket 1/2" wider each side with stock offset shouldn't rub either...
wheelhaus is offline   Reply With Quote
Old 07-17-2014, 09:13 AM   #6
Parikh1234
Sorry the car got on a truck today, I will take some pictures of the rubbing when I get to denver:
http://www.ft86club.com/forums/showt...94#post1850994
Also it seems the clips that hold on the liner fell off, so maybe at speed the air was pushing it back. Just a theory for now.
Old 07-17-2014, 11:29 AM   #7
wheelhaus
wheelhaus's Avatar
That theory makes perfect sense. Airflow from the bumper inlets and from underneath could certainly push it around. Also could be why you haven't noticed it at low speed, because A- it isn't rubbing without deflection, and B- wind noise masks the rubbing noise at speed.
Side note, are you moving to Denver? If so, Welcome!
Old 07-17-2014, 03:15 PM   #8
Parikh1234
Thanks! Not moving to Denver, just shipping the car out there to do some driving of your roads, Denver, Utah, Wyoming, etc. A bunch of us are driving through some of the sites out there.
Old 07-17-2014, 04:29 PM   #9
wparsons
wparsons's Avatar
Stock wheels are 17x7, so your new ones are a full inch wider at the same offset.
flickr
DRL not dim on driver's side jsvegas Cosmetic Modification (Interior/Exterior/Lighting) 5 06-30-2014 10:01 PM
WTB driver side taillights hanabie Want-To-Buy Requests 2 10-04-2013 10:46 PM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
FS: BRZ HEADLIGHT (Driver Side $375) FRS2000 Exterior Parts (Aero, Lighting, Etc.) 0 06-09-2013 11:43 PM
