Northern California NorCal
Old 11-28-2015, 11:44 AM   #1
Tenino
Drives: 13' BRZ
BRZ OEM Wheel Lug Lock Key?
Hey guys,
New owner of a 13' BRZ. I purchased the car from the original owner; however, he misplaced the OEM lug lock key. Does anyone have the key I could borrow to remove the locks? I already bought 4 OEM lug nuts to replace the lock lugs.
Thanks!
*Located in Mountain View*
Tenino is offline   Reply With Quote
Old 11-28-2015, 03:17 PM   #2
dys586
Drives: 2013 Subaru BRZ Premium
Not sure, but I think the key and wheel locks are unique, so you can't just borrow someone's key. Maybe you can go to a dealer and ask to remove them. I think they have like a master key.
Sent from my Nexus 6P using Tapatalk
dys586 is offline   Reply With Quote
Old 11-28-2015, 03:30 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah this guy is right they are unique. (Well like 20 styles or w/e) most dealers do have a master set so they can do it for you and they shouldn't charge to much it only takes 10 minutes.
Old 11-28-2015, 03:51 PM   #4
EzyBrzy
Drives: 2015 WRB BRZ
I lost the key when I had another car. Forgot where I went, but probably some tire shop and they charged me ~$20 to pull them off and installed some spare ones they had laying around.
EzyBrzy is offline   Reply With Quote
Old 11-28-2015, 04:07 PM   #5
dys586
Broke my key and one of the locks on my Civic and had to get it cut off. The lock was cracked and they couldn't remove it without causing damage. If the locks are not on tight and not damaged they should be able to pull them off cleanly.
But, I would recommend seeing if a dealer can just remove them with a master key first before trying to remove them by force at a tire shop and risk damaging your wheels.
Old 11-28-2015, 04:23 PM   #6
Szanzar
Szanzar's Avatar
Drives: 2014 BRZ DGM
The dealership has a "universal" one that they can use to take them off.
Szanzar is offline   Reply With Quote
The Following User Says Thank You to Szanzar For This Useful Post:
soundman98 (02-21-2021)
Old 11-29-2015, 11:52 AM   #7
Srthizz
Drives: Scion FRS RS 1.0 2015
Just go to the dealership. They should have a master set to take it off for you for free. If not I'll help you out. We have a master set at my work in Putnam Toyota on Burlingame.
http://86drive.com
Front engine
Rear wheel drive
Supercharged
Srthizz is offline   Reply With Quote
Old 11-29-2015, 08:51 PM   #8
Tenino
Drives: 13' BRZ
Appreciate the help guys. I'll take it down to Capitol or Stevens creek Subaru and see what they can do!
Old 11-29-2015, 09:59 PM   #9
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
The dealer is your best bet as they do have a master set but there are other options, I personally have done this in the past with other non-mcguard lug nut locks but I only really recommend this as a last option.
[ame="https://www.youtube.com/watch?v=mJUUyjJqk5A"]How To Remove Wheel Locks Without a Key - EricTheCarGuy - YouTube[/ame]
doggieboy09 is offline   Reply With Quote
Old 11-29-2015, 10:10 PM   #10
Tenino
Drives: 13' BRZ
I came across the same video during my research, but that is truly the last resort like you said.
If the two other dealerships refuse to remove the locks, then i'll take up on @Srthizz offer.
Old 11-30-2015, 08:06 AM   #11
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
I had a similar problem (dealer never gave me the key) .
I just wanted them off because I was about to install my new wheels in a month time .
Took it to Toyota only to find out they didn't have my key in stock (to purchase) and they do not carry that size lug nut to replace the locks ..... "Take it to Subaru"
Pish is offline   Reply With Quote
Old 11-30-2015, 04:26 PM   #12
Srthizz
Putnam Subaru is just on the other of the street from Toyota. BTW, You can't just go to any Suburu/Toyota and expect them to have the wheel lock key on the shelf to be sold to customers. These need to be special ordered. And might need some info to get one. Just let me know if you need help.
http://86drive.com
Front engine
Rear wheel drive
Supercharged
Old 12-01-2015, 05:24 PM   #13
ddeflyer
Something like this would probably do the trick: [ame="http://www.amazon.com/Tools-Bolt-Grip-Extractor-5-Piece-394001/dp/B0000CCXVZ/ref=sr_1_1?ie=UTF8&qid=1449008610&sr=8-1&keywords=stripped+bolt+remover"]IRWIN Tools Bolt-Grip Bolt Extractor Base Set, 5-Piece (394001) - Bolt Extractor Kit - Amazon.com[/ame]
Not sure if that is the exact correct size though...
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 02-21-2021, 05:57 PM   #14
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Sorry for bringing up an old thread. This helped me out.
scion fr-s is offline   Reply With Quote
The Following User Says Thank You to scion fr-s For This Useful Post:
WTB: OEM Subaru Wheel Lock Key EarlQHan Want-To-Buy Requests 0 09-14-2015 10:57 PM
Lost wheel lock nut - what to do next? Trikle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-17-2015 12:55 PM
where is the wheel lock key? fatoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-21-2013 11:32 AM
Wheel lock on only one per wheel: unbalanced? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-24-2013 11:37 AM
