Old 11-23-2015, 12:22 PM   #1
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
FA20: Twin or Quad Cam?
So this debate originally sparked from a vinyl design I'm going to be doing in the spring.
Is the Toyobaru engine a twin cam or quad cam? It IS a DOHC that requires two cams to operate the valves. However, it technically has four cams.
I know that it's really just semantics, you could call it either, but I'm curious to hear people's opinions.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-23-2015, 12:29 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Twin overhead cams.
You count number of cams over a single cylinder.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
KR-S (11-23-2015), Shark_Bait88 (11-23-2015), shellslinger (11-23-2015), Sportsguy83 (11-23-2015)
Old 11-23-2015, 01:04 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
^ This
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 11-23-2015, 01:13 PM   #4
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
It's a quad cam DOHC motor. Quad cam just refers to a DOHC motor with two cylinder banks.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Old 11-23-2015, 01:31 PM   #5
xwd
It's funny because some old Subaru marketing literature called it a "Quad Cam" motor, but everything recent they call them DOHC motors. There just happens to be two cylinder heads.
The Following User Says Thank You to xwd For This Useful Post:
Old 11-23-2015, 01:45 PM   #6
Shark_Bait88
Well Quad Cam motors are still DOHC, it's just counted by the total number of cams in the system.
I don't necessarily think there's a right or wrong answer to this. It's a matter of how you look at the system. It's a twin cam in that in order to operate the valves you need two cams, but it's a quad cam if you look at the total number of cams required to make the engine run. In the end it's all semantics and marketing tactics.
The reason I bring this up is because I'm planning to do a vinyl in the spring that's a throwback to the AE86 GT-S factory vinyl:
And I'm decided for the phrasing if I should go with "FR-S TWIN CAM 16"
or "FR-S QUAD CAM 16"
I didn't want to post this part in the OP, because it kinda makes this a thread more for the Exterior section. But since we're debating about the engine, I think I'm in the right place. haha
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
KR-S (11-23-2015), LOLS2K (11-24-2015)
Old 11-23-2015, 01:49 PM   #7
Shark_Bait88
Originally Posted by mav1178 View Post
Twin overhead cams.
-alex
Well there are other V-engines where two cams are used in each bank of cylinder heads and are referred to as "quad cam" motors.
Another example would be you could say a car has a four valve head, or you can say that the engine is a 16 valve.
Both are correct. Just two ways of referring to the same thing.
Old 11-23-2015, 02:30 PM   #8
mav1178
mav1178's Avatar
Just keep in mind what I said.
Twin overhead cams.
Each cylinder head holds two cams that are over the cylinders.
If you want to say there's quad cams, you won't say "quad overhead cams" as that suggests there's 4 overhead cams on each cylinder, you'd just refer to it as "quad cam engine".
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Old 11-23-2015, 02:38 PM   #9
Shark_Bait88
Twin overhead cams.
-alex
I'm not saying you're wrong, just that there are different ways that people phrase it. Basically trying to play devil's advocate.
Old 11-23-2015, 05:50 PM   #10
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Errr no don't do that to ur frs :lol;
The Following User Says Thank You to chaoskaze For This Useful Post:
go_a_way1 (11-23-2015)
Old 11-23-2015, 05:51 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
+1
Old 11-23-2015, 05:58 PM   #12
Shark_Bait88
Meh, it's a little bit of vinyl that my buddy will cut at cost. So it'll cost me barely anything, and is easy to remove if I don't like the look.
Old 11-23-2015, 06:57 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's the wheel urs? Rkr? Size?
Adaptor? Looks like 4x113?
Old 11-23-2015, 07:10 PM   #14
Shark_Bait88
I've got a set of 17x8 +35 RS Watanabe F8s on the way, that will be here in the spring.
That's just a photoshop my buddy did to give a very rough idea of what it will look like. The ones I ordered are actually 5x100, my buddy just grabbed a shot off the internet to use in the photoshop. haha
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
chaoskaze (11-23-2015)
TRD quad diffuser and custon quad tip exhaust Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 16 01-23-2015 05:37 AM
Quad projectors and Quad halos Gixxersixxerman Cosmetic Modification (Interior/Exterior/Lighting) 73 07-05-2014 12:19 AM
J2 Quad Tip Covo_86 Engine, Exhaust, Transmission 5 06-14-2014 10:31 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 08:49 PM
