Old 11-22-2015, 08:53 PM   #1
lupindub
Drives: Scion FR-S
Need advice on flat tire.
So today I ran over something and air started SLOWLY leaking from the driver side rear tire. Thankfully the local tire shop is right next to my work so I just dropped it off in there parking lot (Sunday's closed). So the question I am wondering is should I re-inflate the tire before having the car driven inside the shop? The leak is so small, I think I might be able to inflate it with no problem. Why inflate the tire before driving it into the shop? So the tire doesn't become more damaged then it already is. I heard tires will become ruined if you drive it with no air in them and the rim/tire bead is making direct contact. So even though it is literally a 30 ft drive from the parking lot to the inside of the tire shop garage, should I re-inflate the tires?
Edit: Also is it safe to inflate a tire with a small puncture in it? Or should I just roll it into the shop even on flat tires?
lupindub is offline   Reply With Quote
Old 11-22-2015, 09:21 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
As long as the puncture isn't on the sidewall, it's perfectly safe to reinflate the tire.
That's a really good question about moving the car on a deflated tire. I damaged both passenger tires on a previous car by parking just a little too tightly against one of those residential sloping curbs.
Tires were fully inflated. I rode up just far enough to lift off of the main contact patch and suspend the wheels on the outer corner.
A week later I noticed a big bulge on the sidewall of one of them so I replaced it. A month after that, the other one did the same thing.
I know it's not the same but I'm just thinking sidewalls are pretty fragile.
Old 11-22-2015, 09:34 PM   #3
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
I'm 100% sure the drive from the parking lot into the shop wont hurt it, I've done it countless times. The damage occurs when the rubber is heated up to OT and ran on low or no air that it starts to break down. So any potential damage happened before you parked it.
Tl;Dr You'll be fine, don't stress over it 👍🏽👍🏽👍🏽👍🏽
Sent from my toolbox
86kahl is offline   Reply With Quote
Old 11-23-2015, 08:58 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ok.... So I'm the only one that didn't ask why he just put the spare tire on?
And why would you leave your car just sitting there? Dude.....
Kids these days.
Old 11-23-2015, 09:54 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
My bet is that he didn't put spare tire on most probably due car having it replaced with that stupid and useless tire repair kit. First thing i did to mine was to replace that kit with spacesaver spare i can rely on.
Old 11-23-2015, 12:24 PM   #6
AlexWood
Drives:
I would just mention your concern to the shop when you talk to them. Depending on where you parked, they might just be able to pull the wheel off right there and patch the tire and put it back on and the car wouldn't even have to move.
AlexWood is offline   Reply With Quote
Old 11-23-2015, 01:27 PM   #7
Ultramaroon
not playing cards
Kids these days.
Oh, be nice. He has a slow leak and just drove it to the tire shop. Given the circumstances, I would do the same.
Toyota does this? What if it was more than just a small puncture? I agree. That is a terrible idea.
Old 11-23-2015, 02:16 PM   #8
Pretty sure that at least Asia and Australia only get the repair kit and no spare. North American ones all get spares though.
Old 11-23-2015, 02:17 PM   #9
OK if the tire is low but still has some air in it. A completely flat and pancaked tire can be ruined with just a few feet of driving since the rim can cut right into it.
Old 11-23-2015, 05:06 PM   #10
Ultramaroon
not playing cards
Yeah, that's what I was thinking. I don't have any personal experience but the idea just doesn't sit well with me.
Old 11-23-2015, 05:29 PM   #11
I do!
Old 11-23-2015, 05:59 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
You should carry a can of fix it flat spray thing in the car if you don't no how to change spare/run without spare.
For your own safety!!!
Old 11-23-2015, 06:29 PM   #13
ryoma
ryoma's Avatar
keep in mind that the spare is only for the fronts as well. if you have a flat tire on either of the rear wheels, you shouldn't use the spare (from the manual). I'm guessing it's due to the difference in contact patch of the wheels that will cause it to mess with the rear diff or something
Old 11-23-2015, 06:51 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I had a slow leak once when I was at ACS. Turns out, I picked up a nail on the way to the track.
I drove to a truck stop and they dismounted the tire and patched it on the inside.
I then went back on track and drove a double-stint that day.
-alex
Flat tire...replace or plug? Fugazi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-11-2018 11:24 AM
Tire advice dtrop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 12-03-2014 05:36 PM
Flat tire surrounded by the police. revil Scion FR-S / Toyota 86 GT86 General Forum 49 06-25-2014 04:57 AM
Anyone in Santa Cruz tonight? Flat tire and no OEM wheel lock tool Need help now!!! hail2thetheif Northern California 7 02-16-2014 10:29 AM
Brz Flat - spare stock tire anyone? joergasm CANADA 3 05-30-2013 01:52 AM
