Catted front pipe with headers
Hi guys,
Just need some opinions on this. Im currently running Ace headers with rest stock front and mid pipe, and a STI axle back exhaust. I'm happy with the noise level atm loud when i floor it but quiet enough when im driving normally. Question is if I added a after market catted front pipe how much louder/rasp/drone would i get if any? Ive seen on the forums that some people say itll make it alot louder and others say nothings changed. Does it matter which brand I go with as well?? Keen to do it to save the weight and gain some minor performance. But if it makes it significantly louder or droney then i'll just make do with that I have I was looking at mxp/nividia/ark catted front pipes. I dont want to go completely catless cuz we got strict rules here in aus. Other parts I have on atm are: Greddy intake snorkel Apexi panel filter Mishimoto inlet hose custom tune |
Let me give you some insight on my current setup. I just installed a full header back system this past Saturday. Borla Version 2 UEL catless headers, Invidia Overpipe, Invidia catless front pipe, Invidia N1 Titanium tip catback. It is the closest sounding system to a catless STi. No CEL has came on either. I drove about 100 miles in the past day since install, consistently doing 60-65mph on the highway with Cruise Control. The "drone" to me is low enough to not worry about it. I just turn the radio to 15 VOLUME, and it's gone. Sounds absolutely amazing! If your the kind of person that gets aggravated easily by change, then I say stay with what you have now. If you want to add the front pipe, and over pipe, then do it! It's only a few bolts, even if you don't like it.
Drives: FRS-Raven-MT
I am running a UEL, overpipe, catted front pipe, stock midpipe, and a borla axle back. It is not loud at all. There is a little more "rumble" in cabin over stock but I can barely notice sometimes.
Drives: 2014 GT86
86Hiro: What overpipe addition to Ace's?
![]() It has own integrated to enable longer runner lengths. |
Drives: SWP Subaru BRZ
I'm currently running an Invidia catted front pipe and Q300 with Tomei UEL headers and there is no drone whatsoever. It gets pretty loud when I'm at 50% throttle or above but it returns to stock levels of noise when cruising. As far as adding the front pipe it will get subtly louder.
#6 | |
Adding catless header will make it louder same for adding Hi flow catted front pipe. Adding both those pieces will make it substantially louder than what it is now this is 100% certian. I actually took my hi-flow catted front pipe off and put stock front pipe on as it was too loud with catless header even with one of the quietest catback (HKS legamax). If you are at all concerned about loudness/rasp then just add the catless header and leave the stock catted front pipe in. Its very unlikely to drone with STI axelback. If you are ok with noise level from catless header the frontpipe is easy addition. however it will be substantially louder. If you want it quiet and have catless header and hi-flow cat front pipe, put the stock catback back on. Hi low cat front pipe is only worth a couple of hp or so if you already have catless header. Stock catback flows well it just not the best sound arround. |
| The Following User Says Thank You to steve99 For This Useful Post: | dazbrz (11-22-2015) |
#7 | |
#8 | |
Drives: frs
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 01:32 PM |
| Catted header or catted front pipe? | wilfredwong | Engine, Exhaust, Transmission | 5 | 02-09-2015 07:11 PM |
| Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 02:42 PM |
| Anyone runnign greddy evo 3 + borla headers + resonated front pipe or catted? | SliverBrz | Engine, Exhaust, Transmission | 0 | 10-25-2013 12:37 AM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 01:29 PM |
