Old 11-22-2015, 04:35 PM   #1
mack4477
Drives: 2013 Firestorm FR-S
Street friendly clutches options for boosted car
Looking to switch out the ACT 6 puck I had in the car. Block is being built now, so I'm not sure where I'll end up for torque. I was previously at 330 tq. Need something that will hold ~350 tq+.
mack4477 is offline   Reply With Quote
The Following User Says Thank You to mack4477 For This Useful Post:
trinidadj (07-04-2020)
Old 12-24-2015, 06:50 PM   #2
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
I think the act with the upgraded pressure plate setup is rated at well over 400ft lbs if you get that. Other than that im sure folks can chime in, although finding a street friendly one to hold the torque may be a problem depending on what feel you like haha..
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 12-24-2015, 08:52 PM   #3
FRS Justin
Drives: 2013 Asphalt FRS
I ran a 6 puck N/A and it did great, The wear was increased dramatically but still gave me decent service. When I went F/I I put in a clutch masters twin disc. I ran this clutch setup both N/A and F/I. N/A it was almost impossible to drive, but when I went F/I and had the power it tamed way down a night and day difference. So to get to the point the twin disc is streetable with boost. How long it will last is yet to be seen.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-24-2015, 10:23 PM   #4
twag4
Drives: frs
http://www.ft86club.com/forums/showthread.php?t=94723
twag4 is offline   Reply With Quote
Old 12-24-2015, 11:06 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If you want to stick with a pucked clutch, try an 8 puck (ACT should let you choose on their website. Clutchmasters does the same thing). Closer to OEM grab but still good enough to hold that force.
The Following User Says Thank You to cdrazic93 For This Useful Post:
FRS Justin (12-24-2015)
Boosted Blown Motor Options, Should it Happen Chad86 Forced Induction 25 10-14-2015 01:49 PM
C-Street Wheel options Skurj Tracking / Autocross / HPDE / Drifting 10 09-14-2015 10:51 PM
PSA: ACT vs EXEDY street clutches evan Engine, Exhaust, Transmission 108 05-17-2015 08:31 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal mines13 Other Vehicles & General Automotive Discussions 16 03-30-2012 04:30 PM
