Drives: ZN6
Work Equip wheels 19''- 10.5j -6 off set
Hi
can anyone help me regarding wheel fitment on FRS stock body i am planning for work equip 19'' with 9j +22 front and 10.5j -6 rear..with HKS hypermax IV GT coilovers Suggest tires and other stuff if required to fit above setup perfectly |
Country Boy 4 Life
Welcome to the forum Cuztomizer
http://www.ft86club.com/forums/showthread.php?t=24694. This link has an aggressive setup. I'd check out how they accomplished it... Good luck! Edit: Whoa! -6 rear offset stock body! I'm not sure that will fit... |
Drives: 10 Series #974 6m/t
I think he missed will this fit rocket bunny kit?
Country Boy 4 Life
Drives: ZN6
Dont want to go with rocket bunny
Is thr any way out? |
Drives: 15 BRZ LTD, 05 FXT
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Country Boy 4 Life
I am not an expert. But understand the numbers. Your back wheels are the same width. The offset will push the wheel out an additional 23mm, and require more camber. -6 is already extreme. (yes, in my opinion) I can see the fronts "fitting" but your rear Wheels are going to be difficult. (or impossible)
Here is another thread to read through. http://www.ft86club.com/forums/showthread.php?t=39548 |
| Work Equip 19x8/9, et51/58 | Vten | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-26-2015 07:10 PM |
| FS: Work Equip 01 restored 18x10 -6 18x10 -8 | pokemonphil | Wheels and Tires | 3 | 02-20-2015 03:04 PM |
| new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series | RavSpec | Wheels and Tires | 8 | 06-15-2014 11:07 AM |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 06:19 PM |
