Old 11-19-2015, 01:42 AM   #1
joey999
Drives: frs
What do you recommend with these tires
Have some good grippy tires 215/45/17s on my frs at the moment which are the same tire size as stock.
Looking to buy wheels, what wheel size do you recommend?
I was thinking 17*7+46 but that is really similar to the stock wheel.
What do you guys recommend? 17*8??? Or
joey999 is offline   Reply With Quote
Old 11-19-2015, 06:53 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
If you intend to keep using 215 width ones .. better stay with stock size wheels aswell. The wider the wheel, the heavier.
Old 11-19-2015, 07:48 AM   #3
joey999
Drives: frs
More looks rather than weight. Trying to work out a more aggresive wheel size i could try. Like 17*8 or 9.
Unsure if they will fit however
Old 11-19-2015, 08:03 AM   #4
Cole
Not a troll
Cole's Avatar
You'd be ok with a 17x8. 17x9 is going to be a decent stretch on the tire.
Old 11-19-2015, 08:18 AM   #5
Trettiosjuan
Drives: GT86
Two favourites:
Rota Titan 17x8 et42
Fox FX005 wheel 17x7.5 et35
Look good (concave), not too wild fitment, light (7,7 and 7,4kg resp) and not too expensive.
Trettiosjuan is offline   Reply With Quote
Old 11-19-2015, 08:36 AM   #6
joey999
Drives: frs
Would it look much different going 17*8 or 17*7 ? Noticeable? If so, what offset do you recommend for 17*8
Old 11-19-2015, 08:40 AM   #7
joey999
Drives: frs
[QUOTE=Trettiosjuan;2455994]Two favourites:
Do both these fitment 215/45/17 easily
Old 11-19-2015, 08:47 AM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude search the massive wheel and tire section. It has every combination of wheel and tire you can think of.
Old 11-19-2015, 10:16 AM   #9
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Or go to the manufacturer of the tire - they'll usually have a recommended wheel width listed with their tires.
jawn is offline   Reply With Quote
Old 11-19-2015, 11:18 AM   #10
DarkSunrise
DarkSunrise's Avatar
17x8 would be ideal for you IMO. Can fit a 215 tire with a slight stretch (good for handling), and has the flexibility to take 225 and 235 tires in the future if you decide you want to go wider.
2022 BRZ Build
2013 FR-S Build
Old 11-19-2015, 11:58 AM   #11
8R6
8R6's Avatar
Drives: FRS
i would try to find a set of 17x8 +30
8R6 is offline   Reply With Quote
Old 11-19-2015, 01:13 PM   #12
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Honestly, I would skip straight to a 17x9 and wrap them with 245/40r17's or even a 255.
hmong337 is offline   Reply With Quote
Old 11-19-2015, 03:28 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You should look through galleries and find wheels you like. 17x9 with 225 tires seems to be the performance sweet spot for NA cars. I'm sure an FI car would want more tire. Going for looks is a totally different thing. Also, camber and having coilovers will affect what fits.
Old 11-19-2015, 07:07 PM   #14
joey999
Drives: frs
Would you recommend getting an aftermarket wheels similar to the stock wheel size --- like 17*7+47
Heard its best for performance aspects
Recommend a 0W-40 for me please empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-21-2015 04:08 PM
Headunit recommend boxan59 Electronics | Audio | NAV | Infotainment 1 03-28-2015 05:29 AM
Can you recommend me what to mod next? l0aded Scion FR-S / Toyota 86 GT86 General Forum 26 08-20-2014 11:40 PM
What tires would you recommend? Ludacrits Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 06-22-2013 09:12 AM
I have 3K to spend on my FRS. What would you recommend? lemonspeakers Scion FR-S / Toyota 86 GT86 General Forum 42 03-01-2013 02:24 PM
