Old 11-17-2015, 05:50 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Need a hammer for knocking loose ball joints
What kind of hammer am I looking for?
I had previously been using a ball joint removal tool and it works well but last time it slipped and stripped the thread on the ball joint stud and caused me a huge headache.
Thinking I should try the hammer for now, at least until I get over it.
So what kind of hammer do I need? A dead blow hammer? What weight is good?
Old 11-17-2015, 06:03 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am not a mechanic but I would use this if I could.
The Following 6 Users Say Thank You to go_a_way1 For This Useful Post:
echo419 (11-19-2015), KR-S (11-18-2015), Pat.Thornton (11-19-2015), ScoobsMcGee (11-19-2015), Special_K (11-19-2015), ZionsWrath (11-17-2015)
Old 11-17-2015, 06:04 PM   #3
Attachment 125205
Not sure if you would be worthy!
go_a_way1 (11-17-2015), KR-S (11-18-2015), ZionsWrath (11-17-2015)
Old 11-17-2015, 06:05 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
The "If I could" part is just incase I am not haha. I hope the OP is
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Old 11-17-2015, 08:48 PM   #5
A dead blow or ball peen. The biggest that will fit and still be able to get some ooompf on it will do the task just fine.
Old 11-17-2015, 09:13 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Don't look for a hammer, look for a steel mallet. Dead blows/ball peen take too much effort.
Two taps and ball joints fall out. One swing if good. Something like this.
http://www.perennial.co.nz/abode/686...etalmallet.jpg
They are like $10 about 5-10lbs that's all you need.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 11-17-2015, 09:21 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
[ame="http://www.amazon.com/STANLEY-FMHT56009-FATMAX-Engineering-4-Pound/dp/B00I33UESE/"]STANLEY FMHT56009 FATMAX Engineering Hammer, 4-Pound - - Amazon.com[/ame]
Old 11-17-2015, 09:34 PM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yep that would do. But you could find it cheaper with a basic wooden handle. Unless you'll be hammering all day get that one.
Old 11-18-2015, 05:11 PM   #9
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
you want a Snap-on dead blow hammer.....or of same or equal value.
I was a mechanic and still wrench...you need need the big one and acetalene to remove f-ing dodge truck ball joints and a prayer.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
The Following User Says Thank You to Swift For This Useful Post:
Tcoat (11-18-2015)
Old 11-18-2015, 10:22 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I use both a mini sledge (no idea on the weight) and a dead blow (whatever is closest). Leave the nut on the ball join loosely so you don't hammer the threads
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-19-2015, 04:59 AM   #11
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Just buy a press, less energy and more efficient. It's cheaper in the long run.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 11-19-2015, 08:55 AM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
No, no, and nope. Unless you have girly vegan arms and can't lift 5lbs. Dude $20 for fancy mallet. $10 for a plan one. $50+ for a press. And you can't kill zombies with one. You can with a steel mallet.
And you don't have to place the nut on the ball joint. Unless your going to reuse it.
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 09:14 PM
Wobble, falling apart, loose joints? imravenit Issues | Warranty | Recalls / TSB 25 03-29-2015 10:02 PM
JDL Headers Flex joints JayDee Engine, Exhaust, Transmission 22 02-26-2014 09:57 AM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
Extended ball joints.. tech4pdx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-01-2013 09:53 AM
