ECU update to fix idle problems?
I bought my frs about a month ago and have been experiencing the idle fluctuation probalems like a lot of other members. I thought i read in earlier posts that there was an ecu update to fix the problem, but when i droped by my local toyota dealer in kirkland washington they said that there wasn't an update to fix it yet, but they were working on it. Is there or isn't there an update to fix the problem?
Waited 5 years for this
Drives: '18 MX-5 Club
Does it happen with A/C off? If so, then it might be this.
Check the VIN to see if yours fall into this. |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | ChrisP (11-17-2015) |
my 2015 suffers from idling issues with A/C on, almost stalls when unit kicks on.
| The Following User Says Thank You to B T For This Useful Post: | ChrisP (11-19-2015) |
| idle problems and afr swing | Frs300 | Issues | Warranty | Recalls / TSB | 4 | 01-29-2016 12:14 AM |
| Idle dip but going FI | mscamp02 | Forced Induction | 16 | 11-09-2015 03:16 PM |
| idle problems and afr swing | Frs300 | Engine, Exhaust, Transmission | 2 | 08-16-2015 12:03 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| I know its been covered but 10 series idle problems :( | Aceler8 | Issues | Warranty | Recalls / TSB | 17 | 09-11-2013 12:08 PM |
