Drives: 2013 FRS
install issue, cant break crank loose
So, I cant break my crank loose to save my life. I have it locked in 6th gear so its not free spinning but even with about 2.5 ft of tubing I can't get enough torque to break the bolt loose. It just has a really bad spongy feeling and still very very difficulty, turns the crank. Not sure how else to go about it.
Drives: RX-7 / BRZ
Haven't tried it on this car but, sometimes you can wedge the breaker bar against the floor or frame and bump the starter a bit. MAke sure everything spins the way you need it to before hand though. Also make sure your using a 6 point socket, a 12 point may round it.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Drives: 2013 FRS
ended up having to jam a large screw driver in between the pully and the block in order to prevent that spongy creep.
Thanks. |
| No crank no start issue | *KID* | Issues | Warranty | Recalls / TSB | 3 | 09-29-2014 06:22 AM |
| Issue with Beatsonic Sharkfin (loose after application 2 months out) | iaclimber4 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-22-2014 01:31 AM |
| Unable to loosen crank pulley, even with 6 foot break bar! | tbertran | Engine, Exhaust, Transmission | 36 | 05-20-2014 01:34 PM |
| aFe Install, keep or loose noise generator | jflogerzi | Engine, Exhaust, Transmission | 6 | 01-19-2013 06:50 PM |
| Correlation between CEL issue and break-in habits | switchlanez | Issues | Warranty | Recalls / TSB | 8 | 10-17-2012 10:40 AM |
