Old 11-02-2015, 04:27 AM   #1
tzhu07
Do you aim for perfect parking?
I try to make it a mini-game to see how well I can park my car, instead of "merely" getting within the lines.
I aim for this:
I rarely get it right.
tzhu07 is offline   Reply With Quote
Old 11-02-2015, 04:39 AM   #2
GT86Asia
Drives: 2016 BRZ
Always get it right, even if im one inch off, i have parkophobia so, i go nuts if its closer to one line than the other.
Then just to come back to where i parked and see some jack asa parked inches away from the driver door that i cant get into my car!
I just took a photo, let me resize it and ill post it.....pisses me off when ppl do this.
GT86Asia is offline   Reply With Quote
Old 11-02-2015, 04:44 AM   #3
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
I like parking backwards whenever I have a chance and there's not a lot of cars, makes it easier to get out and looks cool
nova.86 is offline   Reply With Quote
Old 11-02-2015, 05:25 AM   #4
tzhu07
I want to add that I don't back up and repark if it's not perfect. That's going a little overboard.
I'm hoping that over time my success rate with perfect parking gradually increases. Right now I estimate my rate to be under 15% in my slot at home. One of the reasons is that I don't have a long "runway" leading up to the slot in which I can drive straight into it and tweak the steering as I advance. It's a pretty tight underground parking area, so I'm pretty much going into my slot on a curve.
Old 11-02-2015, 07:19 AM   #5
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Sounds like OCD to me.
Braces is offline   Reply With Quote
Old 11-02-2015, 07:20 AM   #6
Teseo
Drives: frs
I park near of a column in multifloor parking lot
Teseo is online now   Reply With Quote
Old 11-02-2015, 07:31 AM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I always park like this, but I'm so good @ it I don't need to try or adjust most of the time. 👻
Drive up & park.l, done in 1go. It very easy if you have a good sense of how wide/how long your car is while in it.
*it took me a while to know where my front lip is when I park thou.
Old 11-02-2015, 08:34 AM   #8
Funny you bring this up because I just noticed the other day that I always seem to park on about a 10 degree angle between the lines. This is not a deliberate action but I am very regular with it.
I am afraid I may be gradually morphing into a Porsche driver!
Old 11-02-2015, 08:46 AM   #9
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
I usually back in, too, but not because it looks cool. I do it because it's easier and more precise, and lets you get into tight spaces (in the unfortunate event that you have NO choice other than to park close to potential inconsiderate/unaware door-ding-producers) with more control. When you turn your front wheels, you make relatively large changes in the direction your front end goes, but the car sort of pivots on the back wheels since they don't change angles and the back end doesn't move a great deal. Soo.. when backing in, you have very precise control of where the back end is headed because of how relatively little it moves in an arc compared to the front of the car. It's sort of like the "lever" principle; you're now using the long end of the lever to control the short end, instead of the other way. Pulling in nose-first is actually more difficult and less precise, once you get used to both methods.
OCD... it's not just a hobby, it's a way of life. Don't leave home without it... but DO leave home!
Best,
Barry
MuseChaser is offline   Reply With Quote
Old 11-02-2015, 08:59 AM   #10
I typically park as shown in the diagram in the OP with a couple of exceptions:
I also center the car front to back, never have understood folks that want to overhang the curb...
I usually try to park in a space with a curb to either side, and when I do I park towards the curb leaving additional space on the driver's side.
When possible I pull forward so I am facing the front (basically as if I had backed in). I will walk further for the opportunity to pull forward and to park next to a curb.
Old 11-02-2015, 09:54 AM   #11
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
Yeah I think once you do enough times it becomes quite easy to park "perfectly" especially for those of us that have to park backwards
For instance with my 9-5 Aero I can't park next to certain curbs (bottom of the door will smack into them) and I have to park backwards in spots with concrete parking stops or I WILL rip my front bumper (and this is all before I lower the car haha)
_____________________
You know what they say... pick two: cheap, fast, reliable.
Joakim3 is offline   Reply With Quote
Old 11-02-2015, 10:13 AM   #12
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I prefer full-blown 90's car show parking. At an angle across three spaces. Wheel completely locked to one side. Hood, doors, and trunk open.
jawn is offline   Reply With Quote
Old 11-02-2015, 10:20 AM   #13
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I always back in my car. I was taught this from working at various shops and dealerships. It reduces the chance of an accident in the lot. When backing into a spot it's pretty easy to see your surroundings. Backing out of a spot is a little harder since these cars are pretty low to the ground and a lot of the view is obstructed by other cars parked next to you. Plus, it feels good to just be able to pull out easily and drive away.
Jesse36m3 is offline   Reply With Quote
Old 11-02-2015, 10:44 AM   #14
Perfect fit frs/brz 255/35/18 831GT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-25-2015 07:19 PM
The perfect FRS/BRZ ravenblackfrs Scion FR-S / Toyota 86 GT86 General Forum 59 01-22-2013 11:23 PM
Perfect Run? yomchi1989 AUSTRALIA 4 01-13-2013 10:38 PM
perfect car! marine321 Scion FR-S / Toyota 86 GT86 General Forum 65 10-19-2012 02:52 AM
perfect parking bay Vladror Scion FR-S / Toyota 86 GT86 General Forum 17 10-05-2012 08:56 AM
