Old 10-31-2015, 01:11 PM   #1
RWDfun
RWDfun's Avatar
Drives: 2015 Asphalt FR-S
Alcantara/Leather Heated seats Swap into FRS Base
Hi guys!
Today I want to share my experience with Swapping heated Alcantara seats from Limited BRZ into FRS Base or Premium BRZ and how to connect them.
First of all I strongly recommend, all wiring jobs were done by professional electrician. (My Friend, who helped me, is a professional electrician, he helped me with all wiring and soldering work, I did wrapping, cleaning, removal and installation work)
ACHTUNG! Everything you do is YOUR own Risk and decision!
Parts you need:
Size:  186.2 KBName:  7610340.gif
Size:  24.0 KBName:  wire_tube.jpg
- Heated Alcantara/Leather seats
- Limited BRZ / FRS RS1.0 console Look #1 (Part Number: 92113CA130 MSRP $51.97 Online Price $39.58)
- Seat heat switch Right Look #21 (Part Number: 83075FA001 MSRP $50.12 Online Price $38.17)
- Seat heat switch Left Look #21 (Part Number: 83075FA011 MSRP $62.97 Online Price $47.95)
- Wires from seats with connectors (which connects to the seats)
- Wires from Buttons #21 with connectors.
- Two wires around 2m length with Subaru pins.
- 3...4 meters of wire tube and tape
- Vacuum cleaner
Direction:
1) Disconnect battery
2) Remove old seats
3) Remove old console Removal console.pdf
4) Remove Switch bezel #13 and side covers #16,17 Name:  7610305.gif
5) Connect two wires about 2m length with Subaru pins to appropriate contacts in harness connector of INTEG UNIT AY USS (part number 88281CA300).
Size:  44.7 KBName:  fuses.JPG
As you can see from pics, even if Base trim doesn't have a heated seats, there are power contacts with fuses from the factory for heated seats needs. We need just connect our power wires with pins to proper contacts in harness connector and we will have proper, designed from the factory power supply for new seats.
look wiring diagrams Wiring diagrams.zip It's can be much easier when you remove module.
6) Stretch out those wires under the dash panel to place under the console where located control buttons and solder them to the wires with connectors for buttons.
7) As you can see from the wiring diagrams, you also have to solder ground cable (my Friend connect it to the car frame).
8) Next step is to connect wires with connectors from the seats to the buttons, wrap them into wire tube and stretch out under carpet to the seats place.
9) Wrap into wire tube all rest of wires and neatly arrange them near other stock wire harness which placed from the factory in FRS Base with MT on the right from transmission.
10) Clean all mess after yourself with vacuum cleaner.
11) Install new console Installation console.pdf
12) Install Switch bezel #13 and side covers #16,17
13) Install new seats and connect properly all connectors.
14) Connect battery
Enjoy every single minute during the cold time your swap
Size:  272.0 KBName:  IMG_20151030_075339.jpg
RWDfun is offline   Reply With Quote
Old 10-11-2016, 04:48 PM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by RWDfun View Post
Hi guys!
@RWDfun thank you for your thread!
Do you have any suggestion if I only need to swap seat to base FRS but do not need the heating funciton?
Iv heard that the BRZ limited seats are not direct fit. There will be sensor issue?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 01-31-2018, 11:09 AM   #3
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
How did you deal with the air bag lights?
Gearbanger is offline   Reply With Quote
Old 01-31-2018, 11:23 AM   #4
RWDfun
RWDfun's Avatar
What do you mean? It's exactly the same connectors on both seats (in my case i put 2012 BRZ seats into 2015 Base FRS) and it was simply plug and play, with no any airbag lights.
Old 12-29-2018, 12:02 PM   #5
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Reviving this slightly old thread.
While I’m here, I have the OEM brz switches but not the wiring connectors for them, anyone know the part numbers for those?
spitsnaugle is offline   Reply With Quote
Alcantara cluster panel or Leather? TilesMeague Cosmetic Modification (Interior/Exterior/Lighting) 12 02-09-2015 01:19 PM
FS: (NoVA) 2008 BMW X3 3.0si -- Fully Loaded, Leather, Heated Seats, AWD - $12800 swift996 Cars for Sale/Trade 1 01-26-2015 08:49 AM
FS: Subaru BRZ LEATHER SEATS/ HEATED-FULL SET FRS-FTW Interior Parts (Incl. Lighting) 9 12-31-2014 06:35 PM
FT: (SOCAL ONLY) FR-S ALL LEATHER SEATS FOR YOUR STOCK CLOTH SEATS ix2vi Interior Parts (Incl. Lighting) 12 07-06-2014 04:49 AM
How do I best clean Alcantara leather seats? Neekowahhhh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-02-2013 05:10 PM
