| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 DGM BRZ
Exhaust Tip - broken bolts
So I bought some GT86 exhaust tips and when I tried loosening the 10mm bolts on my existing ones, they felt seized. So I PB blasted them and tried again, and when I did, the bolts broke.
So...what do I do now? There is no exposed piece or part of the bolt I can grab onto on the exhaust tip. ![]()
EasyOut? Or maybe a Dremel and just cut a slot around the bolt to slide the tip off?
Drives: 2015 CWP BRZ Limited
Or you can cut a slot in it with a dremel and use a flat head to unscrew it further.
#4 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
[insert cool phrase here]
Drives: BRZ Premium
What we do at work is drill out the remaining bolt then use the next size up tap/bolt.
But in this case I would use a dead blow mallet and make the bastard come out. Sure it would gouge the pipe but you'll never see it nor any one else if you put another tip on.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | jbailey8748 (10-31-2015) |
I had this happen to me as well. I opted for the brute force approach and just used the claw of a hammer and beat the shit out of it until it slid off the pipe.
A more rationale approach would have been to use a cut-off wheel on a dremel or drill and cut the bolt off between the pipe and the old tip. More sparks, less banging. |
Drives: 2013 Subaru BRZ Limited (Black)
Honestly even if the bolt came out cleanly I found the tips really difficult to remove. They are sort of crimped on there. I had to seriously fight with mine for an hour to get them off.
Drives: Beep Beep
This happened to me when I over-torqued my bolts. I was lucky and was able to use pliers to grab the threaded-side of the bolt to loosen it from there.
If I remember correctly, I slid under the car head-first, so I was looking at the opposite side of the exhaust tip (the part that faces the front of the car). If you shine a light, you should see the threaded bolt that some pliers can reach to. Last edited by starbot; 10-30-2015 at 11:06 AM. Reason: Added steps |
Drives: BRZ DGM Limited
I had this happen when I replaced the small stock tips with some nicer looking ones from Perrin. What I did was get behind the lower edge of the tip with a screw driver and then pulled down and back at the same time. The lower bottom of the old tip bent and allowed the broken screw to come clear of the pipe. Then I just slide them off. Took some force pulling down with the screw driver, but it worked
#10 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Good on you, I just swapped mufflers with the guy I sold the tips to
Sent from my A0001 using Tapatalk |
#11 |
Drives: 2014 BRZ Limited
Mine just twisted off when trying to take them out. Looks exactly like yours. I took my new tips into a garage, and they put them on for $20
| Exhaust bolts working off over time? | frosty288 | Engine, Exhaust, Transmission | 4 | 09-28-2015 10:55 AM |
| Broken Exhaust Stud During FP Install | EvoPrecision8 | Engine, Exhaust, Transmission | 28 | 03-31-2015 03:21 PM |
| DIY Video - Perrin Exhaust Tip Install! (and how I dealt with broken OEM tip bolts) | CruiseControl | DIY (Do-It-Yourself) Guides | 3 | 06-25-2014 09:05 PM |
| Broken Bolts changing control arm! | benlevy3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 10-29-2012 04:07 PM |
| Exhaust Tips & Broken Bolt | eriktherod | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-07-2012 12:48 AM |
