Old 10-26-2015, 02:16 PM   #1
username404
Drives: 2013 BRZ Limited GB 6MT
OFT+OFH+BPB 93 Stage 2
I'm new to this and wondering if the idle screen shot would say anything about my tune condition or still need to log for the close loop? Thanks!
username404 is offline   Reply With Quote
Old 10-26-2015, 02:34 PM   #2
username404
Hwy 4th @ 55mph
Old 10-26-2015, 03:19 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Yes. You should record/save your logs, rather than take pictures of it.
Also, your LTFT is a little high at idle, and your ambient temperature is broken.
jawn is offline   Reply With Quote
Old 10-26-2015, 03:29 PM   #4
username404
Ambient Temp is now showing correct temp at 57F.
What are the trims I should be at?
How long should I record? 5-10 miles enough?
Thanks.
Sent from my LG-H950 using Tapatalk
Old 10-26-2015, 03:31 PM   #5
username404
Current idleName:  uploadfromtaptalk1445884326734.jpg
Old 10-26-2015, 03:55 PM   #6
jawn
jawn's Avatar
http://www.ft86club.com/forums/showt...01#post1842501
There's good reading in that thread. But yeah, LTFT should be closer to 0. Log a few closed loop pulls and a few open loop/WOT pulls.
The Following User Says Thank You to jawn For This Useful Post:
username404 (10-26-2015)
Old 10-26-2015, 08:42 PM   #7
username404
Kindly check my data please!
93 Stage 2 UEL BPB
'13 BRZ
Old 10-26-2015, 08:59 PM   #8
jvincent
jvincent's Avatar
I'm no expert, but something looks way wrong with that data.
What tune are you running?
Have you checked to see if you have an exhaust leak somewhere?
Old 10-26-2015, 09:03 PM   #9
username404
OTS 93 Stage 2 UEL BPB
Old 10-26-2015, 09:06 PM   #10
username404
I haven't touched or checked the OFH since installed about 1 year ago. Over pipe, front pipe and Catback are OEM.
How would I be able to check the leak?
Old 10-26-2015, 09:10 PM   #11
jvincent
jvincent's Avatar
There's definitely something wrong somewhere.
Your LTFT should not look like it does.
Old 10-26-2015, 09:12 PM   #12
jvincent
jvincent's Avatar
When were the BPB installed?
Old 10-26-2015, 09:12 PM   #13
username404
Oh sorry to mention. Same time as OFH.
Old 10-26-2015, 09:13 PM   #14
jvincent
jvincent's Avatar
It's possible it's been bad like this since the beginning.
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 03:38 AM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 11:16 PM
FBM Stage 1 and Stage 2 Head packages FullBlown Forced Induction 48 02-03-2015 06:13 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 08:29 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 02:32 PM
