Old 10-23-2015, 06:53 AM   #1
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Stock brake caliper rattle
I have a rattling sound coming from the front when going over bumpy or uneven surfaces. It goes away with the slightest touch of the brake pedal. The pads are Ferodo DS2500, and I installed them early last year.
Upon closer inspection, it appears that the calipers have a little play - I can wiggle them with my hand and they would make a rattling sound. The pads themselves are snug on the carrier and don't have any play at all. Any idea on how to fix it? My car only has 12,000km (7,500 miles) so I don't think it is due to worn guide pins. I did not have this problem with the original pads. Help!
HRTROB is offline   Reply With Quote
Old 10-23-2015, 09:48 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Did you verify the guide pins are properly torqued?
Old 10-23-2015, 10:08 AM   #3
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yes, the bolts going to the guide pins are properly torqued. I spent about 2 hours today messing with the front caliper but couldn't find anything.
Old 10-23-2015, 10:10 AM   #4
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
check the indicators/shims and the shield around the rotors, could be bent
#TrackDayBro
Kuri is offline   Reply With Quote
Old 10-23-2015, 10:16 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like your missing the brake pad clips. Those hold the brake pad by the sides to the caliper.
Old 10-23-2015, 10:27 AM   #6
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Took a video. Any idea what the cause might be for all that play?
[ame="https://www.youtube.com/watch?v=hP8XQFvof80"]Toyota 86 caliper rattle - YouTube[/ame]
Old 10-23-2015, 11:00 AM   #7
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Dude looks to me like you got those brake pad clips on backwards. That metal tab should be on the rotor side.
Old 10-23-2015, 11:17 AM   #8
wparsons
wparsons's Avatar
That would have no effect on what he's seeing though...
OP, have you bled the brakes recently? are you sure the slider pin bolts are tight?
Calipers will have a tiny bit of movement if you've recently pushed the pistons all the way in to replace pads, but they shouldn't be doing it like that after driving the car. Possibly air in the system letting out hydraulic pressure?
flickr
Old 10-23-2015, 01:41 PM   #9
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I don't think it's backwards because other photos I've seen have it mounted the same way
That's what I thought, that I might have to re-bleed the brakes. All four calipers have this play even after driving the car for a while, but only the fronts are making the rattling sound. The rears pads are also Ferodo DS2500. The calipers on my other car have no play at all.
The last time I had the brakes bled was two years ago when I changed the brake fluid. I had a shop do the work
Old 10-23-2015, 03:03 PM   #10
wparsons
wparsons's Avatar
Any track days or heavy brake use driving conditions on the current fluid? 2 years without a flush is a long time if it's seeing lots of track driving or hard braking (heat).
flickr
Old 10-23-2015, 08:45 PM   #11
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yes, I've tracked the car a couple of times on the current fluid. However, I installed the pads last July 2014 and the fluid was less than a year old back then but I was alteady getting the rattling sound.
Old 10-23-2015, 09:30 PM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Dam I don't know what else. It's not the clips then maybe it's the pads themselves? Maybe they got worn out really quick?
Old 10-24-2015, 01:46 AM   #13
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The pads still have about 90% left in them, and even if they were worn down to the backing plate, the brakes would have adjusted. That's why we use a C-clamp to push the pistons back in when changing pads, right? I'll try bleeding the brakes since I have to change the fluid anyway.
Old 10-31-2015, 11:39 PM   #14
streety
streety's Avatar
Drives: TOYOTA GT86
I have exactly the same issue on my car. The rattling was present with stock pads/rotors and even after replacing them with Project mu. Replaced guide pins at dealership and no difference.
streety is offline   Reply With Quote
DIY Brake Caliper Painting post_break DIY (Do-It-Yourself) Guides 18 07-20-2018 01:54 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
F1 brake testing. Brake caliper porn! Captain Snooze Other Vehicles & General Automotive Discussions 11 10-16-2015 01:55 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
