Old 10-22-2015, 07:24 PM   #1
Wil
Wil's Avatar
Drives: Drives like a crab.
LED Flasher problem
Hello everyone,
I can't really figure out what the problem is so I'm asking all you GT86 experts!
Because, yes, first things first, the model I'm talking about is a GT86.
I bought a bunch of LED for both the front, tail and side turn signals.
With the stock flasher, as expected, they hyperblink.
What I didn't know is that they only hyperblink when you activate the left or right turn signals, when all turn signals are on (when pushing on the red triangle on the dash), the blinking rate is normal.
So, to solve the problem, I bought another flasher :
http://www.ebay.com/itm/CARCHET-8-Pi...9VrhGn&vxp=mtr
Now, when all turn signals are activated (with the red triangle) I get a slight delay (longer first flash) which I believe I can live with.
But nothing when I turn the turn signals command. No click, no light, nothing.
I only tested with the rear LED installed. Could it only work with LED in all spots?
Thank you in advance for all your inputs and for kindly excusing my approximate english (I hope you didn't laugh too much when I started talking about "the red triangle", haha)
Have a nice day,
RW
Wil is offline   Reply With Quote
Old 10-22-2015, 10:29 PM   #2
stevesnj
stevesnj's Avatar
Thats an adjustable. Use this one
http://www.ebay.com/itm/8-Pin-LED-Fl...xVHIc1&vxp=mtr
My 2016 Build thread
Old 10-23-2015, 02:49 AM   #3
Wil
Wil's Avatar
Thanks for the answer. But, what's wrong with adjustable ones? How do they differ?
Old 10-23-2015, 03:54 AM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I don't see anything wrong with the adjustable ones other than they might cause issues timing wise? Honestly they are not necessary, HOWEVER make sure you test the car with LEDs in all spots just in case.
I personally prefer that if you have the money to spend in the future and enjoy features like tap to switch lanes and such invest in this:http://www3.telus.net/s_mcphee/orderTAP.html
That's what I have in my car, not only does it include tap-turn (i.e mines set to 4 signal flashes when you "tap" the stalk) for quick easier lane changes it's also got some other nice quirks and secret goodies. Also it doesn't delay when you hit the turn signal stalk on the first click (the longer first flash you talked about doesn't appear with this)
Old 10-23-2015, 01:40 PM   #5
Wil
Wil's Avatar
Thanks for the answer. Yes what I did is putting LED in all spots and it works fine now !
No more problem. I hope the thread will help somebody else.
Old 10-24-2015, 06:00 AM   #6
Wil
Wil's Avatar
NExt question:
Is there a way to avoid the first blink delay?
Has anyone ever opened up a flasher and see what was possible to do to fix that problem? Like adding a capacitor somewhere... I don't know.
I'll check by myself, but, if by comparison somebody has ever opened a Valenti flasher and a chinese flasher, if that person could provide pictures, it'd be great :-) !
Have a nice day,
RW
Old 10-24-2015, 06:16 AM   #7
FRSBRZGT86FAN
NExt question:
Have a nice day,
RW
It's literally a normal relay inside, and the only fix I had was getting a high quality relay as I said in my first post with tap turn like this:
http://led86.com.au/home/94-euro-led-flasher-relay.html
or
I personally have the second and don't have the delay you speak of anymore, my old relay however did.
Old 10-24-2015, 07:14 PM   #8
Poodles
Drives: 2015 Series.Blue
Another vote for Tap-Turn here. It's not cheap, but it was worth it for the features it gives me.
Old 10-26-2015, 06:50 AM   #9
Wil
Wil's Avatar
Thank you all for your answer.
Since it's simply an electronical device, I believe it's possible to "mod" it in order to get rid of that delay. That's probably what Valenti or Tap-Turn have done. I don't actually believe it is quality related but rather design-related.
I'll investigate! I believe it could help several people here on the forum.
Old 10-26-2015, 01:56 PM   #10
stevesnj
stevesnj's Avatar
I can wait the 1/2 second more especially for almost $100 for a flasher. I just learned to signal 1/2 sec earlier and saved a bunch of money :P
Old 10-26-2015, 02:58 PM   #11
Cole
Not a troll
Cole's Avatar
I always laugh when I see people talk about how an adjustable flasher relay changed their lives.
Old 10-26-2015, 03:37 PM   #12
Wil
Wil's Avatar
Is their a DIY fix for that first second delay?
BRZ OEM Flasher brzsubarusti13 Exterior Parts (Aero, Lighting, Etc.) 0 04-26-2015 06:56 PM
LED Flasher 6spd Exterior Parts (Aero, Lighting, Etc.) 2 08-08-2014 11:19 AM
Flasher problem after Valenti tail light install! czechm8 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-27-2014 12:00 AM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 02:58 PM
WTB: OEM Flasher Relay CanibeatNoel Interior Parts (Incl. Lighting) 1 03-23-2013 01:19 AM
