Old 10-20-2015, 02:53 AM   #1
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Gear lever rattle
Hi,
Would anyone be able to tell me if getting a Racseng gear knob and reverse lockout help eliminate the gear lever rattle?
I have replaced my gear lever under warranty for the third time now in 1.5 years and the rattle comes back after a few months each time depending on the amount of driving. I have also installed the TRD quickshifter to see if that would help but I took it off this last time to see if that was the cause. I have also tried adding an o-ring and lubing up the shift gear arm link.
It seems like the stock gear level just vibrates itself loose after some driving
So I have been considering trying a new gear knob and reverse lockout to try get rid of this most irritating rattle.
Any suggestion would be appreciated.
Freedom is offline   Reply With Quote
Old 10-20-2015, 11:24 AM   #2
humfrz
What is rattling ...... the shaft or the nob ..... ??
humfrz
Old 10-20-2015, 11:48 AM   #3
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I had the same high rpm rattle from my stock unit.
I have since upgraded to a Raceseng knob and lockout, and do not have any more rattle.
NotSoJDM is offline   Reply With Quote
Old 10-20-2015, 01:10 PM   #4
Lord09
Drives: 2015 BRZ
I've been chasing a shifter rattle for a while and in my case, those two items did not cure my rattle. One easy way to test the reverse lockout would be to remove it and drive around ( reverse will be unavailable so plan accordingly ).
Lord09 is offline   Reply With Quote
Old 10-20-2015, 01:29 PM   #5
Freedom
Freedom's Avatar
I have removed the knob, it still rattled. I never tried removing the reverse lockout completely, however I did try adding teflon tape to the plastic linings inside the reverse lockout so that it became very tight, but it still rattled.
I am struggling to find out where the rattle is coming from. As I said earlier I had the whole thing replaced under warranty three times. It lasts for a while then it eventually comes back.
The rattle is at high. If I rev up to say 7k rpm and let the rpm drop while in gear the rattle is quite bad.
humfrz
I pretty sure it's the shaft.
Old 10-20-2015, 03:01 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
post a video???
Old 10-21-2015, 01:18 AM   #7
Freedom
Freedom's Avatar
I'll do so, when I get the chance.
Old 10-21-2015, 01:17 PM   #8
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
My shifter also rattles, curious about the outcome to this thread.
DylanFRS is offline   Reply With Quote
Old 10-21-2015, 01:19 PM   #9
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
still have it also. no matter what ive done..teflon, new assembly.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 10-21-2015, 01:45 PM   #10
nunonuna
nunonuna's Avatar
Mine also had crazy rattle at higher rpms, but after I installed whitelinr insert & perrin rear shifter bushing a month ago, the rattle seemed to be gone so far. I feel like I got the bonus feature from those two parts because I never expected those bushings to remove that rattle. I call it is the Best 60 bucks spent on my car ever~ I did regret so bad that I put those after 2 yr+ ownership
nunonuna is offline   Reply With Quote
Old 10-21-2015, 01:45 PM   #11
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
humfrz
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-21-2015, 04:47 PM   #12
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I have the kartboy shirt shift. Adding raceseng shift knob did not solve my rattle issue.
Mad_Mike is offline   Reply With Quote
Old 10-22-2015, 01:56 AM   #13
Freedom
Freedom's Avatar
Hopefully, I'll have the video by the weekend. I know this issue has been brought up MANY times but nothing I have tried has worked other than taking it to the dealers every 6 months
The kartboy short shifter replaces the whole oem gear lever, so the rattle is being generated from the gear lever link arm maybe.
After having taking my car to the dealers they removed the gear box and greased up everything in addition to replacing the gear lever. The transmission was like butter, very smooth and hardly any vibration. So if the vibration from the transmission is the cause how on earth is that fixed
Old 10-22-2015, 10:11 AM   #14
nunonuna
nunonuna's Avatar
Get transmission mount insert and rear shifter bushing if you haven't done it.
Gear lever rattle - fixed sav AFRICA 16 01-30-2020 09:22 PM
Ferrari like gear lever ? mashal Scion FR-S / Toyota 86 GT86 General Forum 54 10-20-2015 02:03 AM
Gear lever rattle Freedom AFRICA 0 05-25-2015 04:17 AM
first gear rattle Raves614 Engine, Exhaust, Transmission 11 04-14-2015 10:39 PM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 02:56 PM
