Old 10-17-2015, 08:20 PM   #1
Kregar
Kregar's Avatar
Drives: 2013 Scion FR-S, Asphalt
Boost gauge install
so im installing a boost gauge, first time ive had to install one. Do i install the tjoint on the line going to the BOV or directly off the bigger brake booster line? Check the link for the spots im talking about.
http://imgur.com/a/awEiC
Kregar is offline   Reply With Quote
Old 10-18-2015, 10:48 AM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
It doesn't matter. Although some BOV's recommend a dedicated line for them to maintain fast reaction time, a boost gauge probably isn't going to do anything to that. If you decide to go off the booster line, make sure it's before the little bulge in the booster line, that's the check valve to make sure the booster keeps vacuum.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Kregar (10-18-2015)
Old 10-18-2015, 12:23 PM   #3
Kregar
Kregar's Avatar
Awesome thanks! Yeah i got plenty of space between the bov line and the check valve.
Old 08-12-2018, 10:28 PM   #4
Savoelh
Savoelh's Avatar
Drives: Scion FRS
Not sure if this will help anyone in the future but there is a spot right on top of the intake manifold that you can plug right into.
Savoelh is offline   Reply With Quote
Boost Gauge Help Needed nlowell Forced Induction 19 09-28-2019 11:20 AM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
