Old 10-16-2015, 11:27 AM   #1
Meatstreak
Drives: 2015 BRZ Limited
Renting a Tuner?
This might be a newb question but is renting a tuner a viable option? The only place I have seen that rents them is EcuTek. Are there other places that rent them?
I don't really plan on doing e85 or really many other tweaks. I was considering the recommended tune, header, exhaust but.... it's hard for me to justify spending $500 on this tool that I use once or twice.
Maybe my knowledge is too limited... do you guys use your tuner alot to justify the money spent on it?
Thanks for your opinions.
Meatstreak is offline   Reply With Quote
Old 10-16-2015, 12:20 PM   #2
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
Buy used oft, use it, sell it when done for little loss or small profit
RustySocket is offline   Reply With Quote
Old 10-16-2015, 12:22 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Except that he has to flash back to stock when he sells it.
jawn is offline   Reply With Quote
Old 10-16-2015, 12:49 PM   #4
RustySocket
Slow Learner
Drives: 15 Halo FRS
Yep, thats the way it works
Old 10-16-2015, 03:18 PM   #5
phrosty
Cheapest option is a Tactrix, but it's not the most user friendly.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 10-16-2015, 03:22 PM   #6
RustySocket
Slow Learner
Drives: 15 Halo FRS
I had forgotten about tactrix. That is probably the least expensive
Old 10-16-2015, 03:50 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Well, you essentially use it every time you drive the car because it makes the tune possible. If I were starting from scratch, I'd probably get an OFT. You can keep it plugged in for all sorts of data logging. You would do the same for EcuTek, but they're really only good for making some tuners happy and doing flexfuel. Tactrix, which I have, is a bit of a paint to use. You're also more likely to brick the ECU.
Old 10-16-2015, 06:02 PM   #8
steve99
When you "rent" a tuner from an ecutek dealer your just renting the cable.
to use the cable to "tune your car you will need an ecutek licience and they are about $300 and non-refundable.
Then you also need a "tune" unless your going to develope the tune yourselft from scratch.
you can just get an ecutek tuner , or possible another tuner to flash you a tune to your car. This will cost about $600 for a flash and go tune if you can get to tuner.
you just leave with the tune in ecu.
If you dont live near an ecutek tuner then you can rent the cable to be able to flash tune.
Alternatively you can buy an OFT and it is a tuning device that comes with a set of tunes costs $500 and has other features such a gauge displays and engine parameter alerts like for oil coolant temps of knock ect.
Or if you do a fair bit of learning you could use tactrix.
see below.
CSG Mike (10-20-2015)
Old 10-20-2015, 04:53 PM   #9
Meatstreak
Awesome. That cleared up alot of things I was thinking about. Thanks everyone for your thoughts.
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 05:39 PM
Renting a fr-s /brz Vincenttam Southern California 14 05-14-2015 09:33 PM
Renting an FR-S/BRZ in Los Angeles Dihudaxia Off-Topic Lounge [WARNING: NO POLITICS] 10 08-30-2014 06:38 AM
Looking for a TUNER fujiwara_tofu Software Tuning 12 11-23-2013 05:15 AM
I'll be renting a BRZ to take on the Nurburgring in 3 weeks davtbaum BRZ First-Gen (2012+) — General Topics 7 06-25-2013 06:31 PM
