Old 10-16-2015, 05:42 AM   #1
Arcade_West
Drives: Subaru BRZ
Potential knocking at low rpms/crap fuel?
Hi guys. I've got a BRZ with sprintex (innovate) 69mm pulley supercharger, tuned using ecutek.
It has been great up until i drove it the other day, and it started acting weirdly. I was going 85km/h in 6th gear [~2000 rpm], put my foot down, and got 0 power. no rpm increase, just tractor noises. Usually it may bog down a tiny bit, but it would always take off shortly after. It has also been hesitating occasionally when i put my foot down in any gear at low rpms, then it gains power back at about 3000-4000 rpm usually.
My guess is that its detecting knock, and the ecu is retarding the spark causing a lack of power. This has only started happening recently, and has been fine for 3-4 months before. Is it possible that I have just got a crappy batch of fuel, or would it more likely be the tune? Sorry if this has been posted in the wrong place.
Thanks
Arcade_West is offline   Reply With Quote
Old 10-16-2015, 05:59 AM   #2
steve99
could be many things
log the ecu parameters when it occurrs and send it to tuner.
might be running rearly rich or load limits set incorrectly .
could be exhaust leak causing ecu to run engine rich
Old 10-16-2015, 08:16 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Without a log and an idea of what's happening then it'll be very hard to diagnose. Have there been any big changes in conditions? Also with this kit, try not to go WOT is a high gear at low RPM. It doesn't like it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-17-2015, 08:58 PM   #4
Arcade_West
Drives: Subaru BRZ
No real changes in condition, only thing that has changed recently is installing new wheels/tyres, however i was driving it for a couple of weeks with them and it was fine.
Old 10-17-2015, 09:45 PM   #5
D_Thissen
D_Thissen's Avatar
These motors don't like a combination of high load (foot down) and low rpm (~2000). If you can, try to post some data logs, hopefully someone can help you out!
Old 10-20-2015, 11:55 AM   #6
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
This sounds like the infamous vacuum leak on the back of the supercharger. This is a pretty well known problem on these kits. The plastic fittings will loosen up over X amount of heat cycles and cause the car to run poorly at low rpm.
I would check those fittings to see if they are loose. If so you can either replace them with brass fittings or use plumbers tape to reseal them.
Cheers,
William Knose
Old 01-22-2016, 02:22 AM   #7
Arcade_West
Drives: Subaru BRZ
Cheers,
William Knose
Cheers
Yeah my fittings have already been replaced with brass fittings. I have taken it back to the tuners a few times, and it is STILL knocking below 3500rpm. At bang on 3500rpm it liven sup again. The tuner has tried to say that its just the hot weather, but it even does it at ambient temps of like 20degC. Not really sure what to do from here :/
Old 01-22-2016, 03:26 AM   #8
steve99
Originally Posted by Arcade_West View Post
Cheers
These engines are very swnsitive to crap fuel at low rpm medium to high load probably more ao with sc fited
Run the best fuel you can also try different brands of cuel some are much better than others
Old 01-26-2016, 02:25 PM   #9
86fun
Drives: 2013 FRS
I seem to be having the same issue with my newly installed Edelbrock kit. Good tip about checking for leaks, I'll do extra searching on my setup for these knowing this could produce the same result we're experiencing. I've already tried two different sources of fuel. Curious to hear what fixes your Arcade!
86fun is offline   Reply With Quote
Old 01-26-2016, 07:09 PM   #10
Arcade_West
Drives: Subaru BRZ
I will let you know what the issue is when i find it haha
I have tried different fuels, and still get the same issue as well. I'm going to look at the bypass valve and other vac lines when I get the chance.
RPMs for best 0-60 MurderRider Scion FR-S / Toyota 86 GT86 General Forum 8 07-19-2014 01:29 PM
Crap, is this anyone on here? dori. Northern California 6 03-24-2014 10:28 PM
Well crap FirestormFRS Issues | Warranty | Recalls / TSB 6 03-10-2014 12:31 AM
Crap, the got me... Mandy Member's Car Journals 4 02-01-2013 03:31 PM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 10:51 AM
