Drives: car
Shift rod bushing?
So after a clutch install I've begun to notice some play in the shift lever in every gear including neutral. Wondering what I should do, well I first looked at the perrin rear shift bushing and the whiteline insert, which seem like a good option, but I'm also looking to see if there is a bushing for the shift rod / linkage, seen in this pic below:
![]() I've seen some youtube videos claiming that these are the bushings you need to replace if you experience some play in the shifter. Are there any aftermarket bushings for this? |
Drives: 13 Sc10n FR-S
Whoever did your clutch left them out, but yes those are them there's also a washer and that o-ring that you will need
Sent from my D6708 using Tapatalk |
Drives: car
ok so I guess that oem parts are the only option?
Unless you want to upgrade to a short throw shifter Ya pretty much
Drives: 2013 Firestorm FRS
you can throw some super thin washers in there, I know I got some from Kartboy here on the forums.
That would only help side to side but not front and back
Drives: car
Bumping. I need a guide for this. Like what size o-ring?
...Just add nauseum
Drives: 2003 (AP1) S2000
...Oooor you could take the thing to any decent machine shop with the bolt, and they can make a press-in solid bushing on a lathe. Forget all the rubber crap. Then put some grease between the bolt and the bushing and be done with it.
There are many ways to displace.
-Spartarus |
#9 | |
Drives: car
Maybe you go ahead and try that first, let us know the results! |
#10 |
I'd go with delrin over brass, easier to machine and won't make noise if it has a tiny bit of play.
#11 | |
...Just add nauseum
I was giving you advice on fixing yours, but I have never had a single problem with mine. I'm not in a hurry to spend unnecessary money, seeing how I have a massive pile of expensive and (arguably) equally unnecessary projects already. I like your thinking.
-Spartarus |
#12 |
Drives: renault clio rs
Revolution make´s ones.
http://revo-tune.jp/catalogue/detail.php?id=332 ![]() https://www.japanparts.com/parts/detail/44420 |
#13 |
Drives: car
| SOLD: Perrin Shift Bushing - $27 shipped | JonnyRocket | Transmission and Driveline | 0 | 09-08-2014 11:50 PM |
| Whiteline Positive Shift Kit Bushing | SlyCayer | Engine, Exhaust, Transmission | 5 | 08-08-2014 09:33 AM |
| Whiteline Shift Bushing #926 | jack43 | Transmission and Driveline | 1 | 03-13-2014 07:09 PM |
| BEST MOD I'VE DONE YET: Perrin Rear Shift Bushing | bobpuffer | Engine, Exhaust, Transmission | 9 | 12-23-2012 01:52 AM |
| Whiteline Positive Shift Bushing? | wootwoot | Engine, Exhaust, Transmission | 20 | 11-05-2012 07:45 PM |
