Old 10-14-2015, 08:45 PM   #1
radroach
Drives: car
Shift rod bushing?
So after a clutch install I've begun to notice some play in the shift lever in every gear including neutral. Wondering what I should do, well I first looked at the perrin rear shift bushing and the whiteline insert, which seem like a good option, but I'm also looking to see if there is a bushing for the shift rod / linkage, seen in this pic below:
I've seen some youtube videos claiming that these are the bushings you need to replace if you experience some play in the shifter.
Are there any aftermarket bushings for this?
Old 10-16-2015, 03:49 AM   #2
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Whoever did your clutch left them out, but yes those are them there's also a washer and that o-ring that you will need
Sent from my D6708 using Tapatalk
StegaDragon is offline   Reply With Quote
The Following User Says Thank You to StegaDragon For This Useful Post:
jbailey8748 (10-31-2015)
Old 10-16-2015, 12:03 PM   #3
radroach
Drives: car
ok so I guess that oem parts are the only option?
Old 10-16-2015, 12:09 PM   #4
StegaDragon
Unless you want to upgrade to a short throw shifter Ya pretty much
Old 10-16-2015, 12:15 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
you can throw some super thin washers in there, I know I got some from Kartboy here on the forums.
Old 10-16-2015, 12:26 PM   #6
StegaDragon
That would only help side to side but not front and back
Old 12-15-2015, 10:19 AM   #7
radroach
Drives: car
Bumping. I need a guide for this. Like what size o-ring?
Old 12-15-2015, 02:10 PM   #8
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
...Oooor you could take the thing to any decent machine shop with the bolt, and they can make a press-in solid bushing on a lathe. Forget all the rubber crap. Then put some grease between the bolt and the bushing and be done with it.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
jcw99 (12-15-2015)
Old 12-15-2015, 02:25 PM   #9
radroach
Drives: car
I've thought about how neat a solid brass bushing would be. They have them for WRX and STi, why not for BRZ's?
Maybe you go ahead and try that first, let us know the results!
Old 12-15-2015, 02:30 PM   #10
wparsons
wparsons's Avatar
I'd go with delrin over brass, easier to machine and won't make noise if it has a tiny bit of play.
flickr
Spartarus (12-15-2015)
Old 12-15-2015, 02:58 PM   #11
Spartarus
...Just add nauseum
Spartarus's Avatar
Well, there's that old adage about broken things.... The word "ain't" is somewhere in there... Not a huge fan of the word ain't... Anyway, I'm sure the phrase will come to me...
I was giving you advice on fixing yours, but I have never had a single problem with mine. I'm not in a hurry to spend unnecessary money, seeing how I have a massive pile of expensive and (arguably) equally unnecessary projects already.
I like your thinking.
-Spartarus
wparsons (12-16-2015)
Old 12-18-2015, 03:37 PM   #12
Riki
Drives: renault clio rs
Revolution make´s ones.
http://revo-tune.jp/catalogue/detail.php?id=332
https://www.japanparts.com/parts/detail/44420
Riki is offline   Reply With Quote
The Following User Says Thank You to Riki For This Useful Post:
radroach (12-18-2015)
Old 12-18-2015, 05:26 PM   #13
radroach
Drives: car
SOLD: Perrin Shift Bushing - $27 shipped JonnyRocket Transmission and Driveline 0 09-08-2014 11:50 PM
Whiteline Positive Shift Kit Bushing SlyCayer Engine, Exhaust, Transmission 5 08-08-2014 09:33 AM
Whiteline Shift Bushing #926 jack43 Transmission and Driveline 1 03-13-2014 07:09 PM
BEST MOD I'VE DONE YET: Perrin Rear Shift Bushing bobpuffer Engine, Exhaust, Transmission 9 12-23-2012 01:52 AM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
