Old 10-14-2015, 03:47 PM   #1
jonnyfrank
Ordering 245/40/17 x 7
I have decided on the Michelin Pilot Super Sports 245/40/17 x 7. I drive the BRZ a few times a week as it is a second car. My teenage boys will drive it now and again as well.
I will be using stock wheels.
Tires and wheels give me a headache. I have gotten several opinions but want to hand it over this board for any final critiques and thoughts.
Thanks in advance.
And yes, I know there are threads with the tire and wheel conversations and I have read thru them. Just looking for a final opinion here. Thanks!
jonnyfrank is offline   Reply With Quote
Old 10-14-2015, 03:52 PM   #2
STV3
Señor Member
STV3's Avatar
Why do you want such a wide tire? A 245 is really too wide a tire for a 7" wide rim. Why not just go with a MPSS in the stock 215 size.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
jonnyfrank (10-14-2015)
Old 10-14-2015, 03:54 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
The 17x7 refers to the size of the stock wheel.
The tires you need are 215/45/17.
Nothing is going to be better than that for you.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Old 10-14-2015, 03:58 PM   #4
kch
Senior Misanthrope
kch's Avatar
I disagree. I have PSS 225/45/17 on stock wheels and rather like the setup.
But yeah, 245 is way too wide for stock wheel.
The Following 3 Users Say Thank You to kch For This Useful Post:
Grateful Dave (10-14-2015), jonnyfrank (10-14-2015), Special_K (10-14-2015)
Old 10-14-2015, 04:05 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Yeah, the tread width on those 245/40/17s is 8.5 inches. Michelin recommends between 8 and 9.5" wide wheels for those tires.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 10-14-2015, 04:24 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I run a 225 as well I like it alot. But like others said 245 is too much for a stock rim. on a 225 my side wall sticks out further then the rim to the point that I dont think a 245 could even fit safely
Old 10-14-2015, 04:30 PM   #7
STV3
Señor Member
STV3's Avatar
If you take a look at the specs on the 215/45 Mich PSS. The tread width is 7.7" which is more than enough for a stock 86.
http://www.tirerack.com/tires/tires....SSXL&tab=Specs
I'd say the stock 215/45 size would be your best option for the stock wheels.
Old 10-14-2015, 04:41 PM   #8
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
Listen to these guys jonnyfrank... You definitely won't be safely fitting 245s on a 7" wheel. I've got 225s on my 8" wheel and although I could definitely go wider, I probably wouldn't unless I added more power. 245's honestly don't even make that much sense to run on a car this light and with such low power.
I'd say, 225's max on the stockers.
Special_K is offline   Reply With Quote
The Following 2 Users Say Thank You to Special_K For This Useful Post:
jonnyfrank (10-14-2015), STV3 (10-14-2015)
Old 10-14-2015, 05:15 PM   #9
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Some of fastest guys are running 225/45 at the track. 225 makes more sense on a 7" wide wheel, even from a performance standpoint.
LOLS2K is offline   Reply With Quote
The Following 2 Users Say Thank You to LOLS2K For This Useful Post:
Old 10-14-2015, 06:11 PM   #10
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Actually 225 fits best on a 7.5" wide rim.
Stock rim I would run 215 as that's the best fit.
I'm running 215/45/17 on my 7.5" wide rim and I can corner plenty fast with good handling.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
Old 10-14-2015, 06:21 PM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Each tire brand have different width of tires. 215 doesn't mean all 215 are same.
Anyways, 245/40-17 is a bit for 17x7
Check this article. It's a good read
http://www.motoiq.com/MagazineArticl...RFORMANCE.aspx
Old 10-14-2015, 06:42 PM   #12
bobka7914
Drives: ‘22 BRZ, ‘18 Crosstrek
For BRZ stock rims: PSS 225/45ZR17 or PSS 215/45ZR17?
Also, where can I find best prices on average: TireRack?
bobka7914 is offline   Reply With Quote
The Following User Says Thank You to bobka7914 For This Useful Post:
Old 10-14-2015, 06:45 PM   #13
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
I don't even think a 245 will seat onto a 7" wide wheel, stick with 215-225 wide. 245/40/17 should have a minimum 8" wide wheel.
Sweet48 is offline   Reply With Quote
The Following User Says Thank You to Sweet48 For This Useful Post:
Old 10-14-2015, 07:50 PM   #14
8R6
8R6's Avatar
Drives: FRS
215/45 or 225/45 on the stock 17x7 size is perfectly fine. 245/40 is a no go... it's like opposite of super stretched tires on those stanced out cars lol.
215/45 is stock size like people have mentioned, but 225/45 also works just fine (or even "better" subjectively) as a lot of people have also mentioned.
i'd just stick with 215/45 size with decent sticky tires. compound > width
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Ordering a FR-S becauseracecar1 Scion FR-S / Toyota 86 GT86 General Forum 19 03-27-2014 01:24 PM
Ordering From The Factory? iBRZ BRZ First-Gen (2012+) — General Topics 25 11-21-2012 07:12 AM
I need ordering help (Prem. vs Lmt) Bones36 BRZ First-Gen (2012+) — General Topics 59 08-29-2012 01:46 PM
Ordering process. Davetherave CANADA 5 08-10-2012 03:46 PM
Waiting/Ordering geb2391 Southern California 0 07-27-2012 07:57 PM
