Old 10-13-2015, 12:08 AM   #1
lx93
Drives: 2013 BRz Premium
help! crankcase pressure and oil drainage
about half a year ago I upgraded my Vortech v3 into v2 unit. it turned out that Vortech sent me a defective unit and the impeller center shaft was popped out and it was not making full boost. Under warranty I sent the unit back. Just received the rebuilt unit back and installed it on the car. After a spirited driving session, the supercharger started dripping oil out of casing. Seems like the seal is leaking. Here is a video of it
[ame="https://www.youtube.com/watch?v=0MV9Bfop1gk"]https://www.youtube.com/watch?v=0MV9Bfop1gk[/ame]
I am suspecting excessive crankcase pressure is preventing oil to flow back in return line. I have a PCV check valve installed as well, so the boost is not pressurizing the crankcase. I have Crawford AOS installed as well with this setup, so now I am suspecting if that's the issue here. Do people have similar setup as mine and have similar issues? Thanks
lx93 is offline   Reply With Quote
Old 10-13-2015, 03:12 AM   #2
sw20kosh
Drives: 2013 Black FR-S
No people do not have this issue. My buddy has v2 setup and he doesn't have any issues even on the racetrack. This is probably a bad vortech unit or overfill etc...
Old 10-13-2015, 07:00 AM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
RMA it again!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Radium Catch Can Kit (Crankcase Breather) sw20kosh Engine, Exhaust, Bolt-Ons 3 03-10-2016 09:23 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
