Old 10-12-2015, 03:40 PM   #1
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
Setup Inquiry
So I have been browsing the forums for some time now and am looking over the information on different exhaust setups, manufacturers, and so forth. Currently, I am just running with a K&N drop-in filter and Nameless 2.5" axleback with 5" mufflers. I prefer this over the stock exhaust but I am far from satisfied as it does not have the tone that I desire. I would like to have a setup that has that nice boxer rumble but not obnoxious when I feel like driving a bit more spirited than usual. Noise is not much of an issue as I will be moving out of a HOA community to another area with ample separation between neighboring houses and I rarely hit WOT. Additionally, I am not worried about smog tests here in Florida but I do intend to get a tune to fix the CEL issue from going with a catless header.
I purchased an Invidia overpipe and Invidia front pipe (catless) from another member locally that is just sitting in the garage for now but I suspect that I will likely need to get a catted or resonated front pipe with the header/cbe setup I want which I have listed below this. Now for my inquiry, is anyone running with the JDL UEL Header and Perrin 2.5" Restonated CBE on a NA twin? If so, what OP/FP combo do you have? I am trying to decide on what front pipe that I should go with that is catted or resonated. Right now, my options are between the Invidia resonated front pipe, JDL catted front pipe, and Nameless Performance catted front pipe with or without the overpipe too.
Videos of the JDL UEL Header/Perrin CBE setup would be nice. I've already looked at a few online so it is coming down to the OP/FP combo that I need to decide on.
Possible Setup
  • JDL UEL or Tomei UEL Header
  • Invidia, JDL, or Motiv OP
  • Invidia, JDL, or Motiv Catted FP
  • Perrin 2.5" Resonated CBE
▰▰▰ 2014 Scion FRS: Bagged & Wide
▰▰▰ INSTAGRAM: @frsmichael
▰▰▰ BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 10-12-2015, 04:47 PM   #2
humfrz
Originally Posted by Michael View Post
So I have been browsing the forums for some time now and am looking over the information on different exhaust setups, manufacturers, and so forth. Currently, I am just running with a K&N drop-in filter and Nameless 2.5" axleback with 5" mufflers. .......
Possible Setup
  • JDL UEL Header
  • Invidia Overpipe?
  • Invidia Front Pipe (Catless)?
Well, @Michael, whatever you decide ........ I wouldn't throw/sell/give away your present setup. Just in case you want to go back to a set up where you can hear yourself think while driving........
humfrz - is no fun .....
Old 10-12-2015, 04:55 PM   #3
Michael
Lovin' the Low Life
Michael's Avatar
I figured a resonated or catted FP with the resonated Perrin CBE would help a little bit instead of using the catless FP that I have right now.
Old 10-12-2015, 04:56 PM   #4
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Possible Setup
  • JDL UEL Header
  • Invidia Overpipe?
You may want to keep a cat in the front pipe. Will help keep the rasp down.
With the JDL header you will want the Perrin Resonated exhaust for sure. That will be one nice sounding set up, will also be pretty loud.
You could always keep the stock mid pipe, and hold of on buying the Cat Back and keep the muffler back to see if that is pleasing
GotBRZ1691 is offline   Reply With Quote
Old 10-12-2015, 04:58 PM   #5
Michael
Lovin' the Low Life
Michael's Avatar
Great suggestion. I was looking into doing this as my purchase order would be header > OP/FP > CBE. Since the Perrin CBE occasionally goes for sale from another owner from time to time, I'm in no rush for that yet to save a little bit.
Old 10-12-2015, 05:17 PM   #6
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Found this on youtube:
[ame="https://www.youtube.com/watch?v=iaEmGG3DTZA"]JDL UEL headers BRZ - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=-fcihx8rCk4"]Subaru BRZ JDL UEL Header, Catted Nameless DP/OP w/Helmholtz, Perrin Res Catback 2.5" - YouTube[/ame]
jawn is offline   Reply With Quote
Old 10-12-2015, 05:26 PM   #7
Michael
Lovin' the Low Life
Michael's Avatar
^ Watched both of those earlier today. I like the JDL OP/FP combo a little bit more but still undecided.
Old 10-12-2015, 05:28 PM   #8
jawn
jawn's Avatar
I thought the first video was a little raspy, to be honest, which is not really my thing.
Old 10-12-2015, 05:52 PM   #9
Michael
Lovin' the Low Life
Michael's Avatar
It seems that it can get raspy at higher RPMs but that could be the video itself.
Old 10-14-2015, 02:02 PM   #10
Michael
Lovin' the Low Life
Michael's Avatar
Now I am torn between the JDL UEL and Tomei UEL. Ugh...
Old 10-14-2015, 02:13 PM   #11
jawn
jawn's Avatar
There's also the Gruppe-S UEL header, which is more-or-less a white label Tomei, and priced accordingly.
Old 10-14-2015, 02:37 PM   #12
kch
Senior Misanthrope
kch's Avatar
If you haven't seen mine already, this is with JDL UEL, JDL OP, JDL UQFP, and Perrin 2.5" resonated, running E85. Headphones recommended:
[ame="https://www.youtube.com/watch?v=VnEYvkiW5k0"]BRZ w/ JDL UEL & Perrin resonated drive by - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=y1kyhCzlx-o"]BRZ w/ JDL UEL & Perrin resonated 2.5" revving - YouTube[/ame]
Old 10-14-2015, 02:39 PM   #13
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I concur, JDL uel plus perrin(3") sounds great but it is loud(especially since I'm supercvharged)
fumanchu1 is offline   Reply With Quote
Old 10-14-2015, 02:54 PM   #14
Michael
Lovin' the Low Life
Michael's Avatar
Thanks for that suggestion. I'm reading up on the threads for this header right now.
Yeah, I have watched both of those videos among many others.
exhaust, frontpipe, header, overpipe
body inquiry Diz86x Cosmetic Modification (Interior/Exterior/Lighting) 1 07-04-2015 12:29 PM
Screw Size Inquiry PHOsho BRZ First-Gen (2012+) — General Topics 6 05-20-2014 09:15 PM
Winter inquiry Brandar Northwest 18 11-28-2013 01:41 PM
TRD Exhaust inquiry? Realm Engine, Exhaust, Transmission 2 02-27-2013 01:18 PM
Another dealer inquiry (vic ***) xeri AUSTRALIA 8 05-08-2012 10:58 PM
