Old 10-11-2015, 09:29 PM   #1
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
New Solid Subframe Bushings - Install Pics
We just finished test fitting our first production batch of solid aluminum rear subframe bushings. These are truly solid replacements for the rear subframe and differential bushings these are a tight press fit and completely eliminate bushing flex and differential movement. They also raise the subframe almost .25" which helps correct geometry on lowered cars. These are machined from billet 6061 T6 and anodized gold or black.
Also available in black
http://store.carolinadyno.com/produc...ntial-bushings
Carolina Dyno is offline   Reply With Quote
Old 10-12-2015, 08:24 AM   #2
mrk1
Drives: Sterling BRZ Ltd
Very cool, sure looks like you took the time in designing them, not just chunks of aluminum with a hole down the middle.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-12-2015, 03:08 PM   #3
Carolina Dyno
Drives: 2013
Yep, every ounce counts. There is no excuse for lazy engineering and we're surrounded by it.
Old 10-12-2015, 03:29 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
whoa! Those sure do look pretty!
revolution garage rear subframe solid bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-01-2015 10:09 AM
100% Solid Press Fit Steering Rack Bushings Carolina Dyno Brakes, Suspension, Chassis 9 04-17-2015 04:44 PM
options for solid rear subframe bushings? mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-26-2014 10:30 PM
Turn in Concepts Solid Steering Rack Bushings Proof Brakes, Suspension, Chassis 3 03-18-2014 09:42 AM
Solid Steering Rack Bushings (Press Fit) Carolina Dyno Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-03-2013 12:13 AM
