Old 10-04-2015, 03:15 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Exclamation Differential Bushing Insert Install Issue - Tranny won't shift
I installed the AvoTurbo differential bushing inserts this afternoon and when I got in to test drive the car it wouldn't shift into reverse or any other gear.
I did the install with the tranny in first gear and the rear jacked up with the wheels still on (rear on jack stands). i hand tightened the 3 bolts back and then finished tightening the bolts with the car on the ground.
the install was easy and I didn't feel like I forced anything. The transmission slipped from first to neutral but now won't go into gear at all. I didn't touch any other part of the car (I do have the transmission inserts but that was done a while ago).
Appreciate any help I was was going to road trip with the car tomorrow.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Whiteline differential insert bushings review Mikepage Engine, Exhaust, Transmission 149 11-04-2020 10:12 PM
DIY__twincamRob's 5min Whiteline Positive Shift bushing install twincamRob DIY (Do-It-Yourself) Guides 30 06-30-2017 10:27 AM
KDT 925 outrigger bushing insert clintavo Brakes, Suspension, Chassis 3 05-28-2015 12:58 AM
DIY - AVO Transmission Mount Insert Bushing AVOturboworld DIY (Do-It-Yourself) Guides 0 06-04-2014 08:19 PM
tranny is whining after putting the whiteline positive shift kit bushing? mtsui Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-13-2013 11:51 PM
