Old 10-03-2015, 06:07 PM   #1
radroach
Drives: car
Can I reprogram my head unit with someone else's SD card?
My car battery was disconnected, and that rebooted my BRZ Radio/NAV HU. It requires the SD card to reprogram the car, but I was never given one when I bought my car. I'm wondering, if I'm able to borrow an SD card off another car / driver with their permission, can I reprogram it with their card?
Old 10-03-2015, 06:22 PM   #2
swarb
Card is in the head unit. Look for it. It should be ok to use another card.
Old 10-04-2015, 09:22 AM   #3
P3tras
Drives: Subaru BRZ '13 WRB
You can use different card, but it will work until first power loss (battery disconnect).
P3tras is offline   Reply With Quote
Old 10-04-2015, 10:36 AM   #4
radroach
Drives: car
My car never included one. I got mine with 50 miles on it when I bought it, nav sd card was missing. Dealer refused to give me one.
Old 10-04-2015, 10:58 AM   #5
athlon816
athlon816's Avatar
Drives: brz
I can send you the file
来自我的 HTC One 上的 Tapatalk
athlon816 is offline   Reply With Quote
Old 10-04-2015, 07:26 PM   #6
P3tras
Image will not work. Files on each SD card are encrypted to SD card CID number. You have to use original SD card. There is no workaround with this issue (unless something changed during last couple months). I spent days searching for info how to use data on different SD card with no success
Old 10-04-2015, 08:11 PM   #7
Vmax911
Drives: WRB BRZ
Agree with the above. I bought an SD card with newer map set off of eBay. Swapped SD cards and enjoyed the updated maps. Several months passes until I had my battery go dead. Upon getting the car started, my headunit reset and I was unable to use it until I found my original card. Once it booted, I was, able to swap to the new card again.
Sounds like you had better talk to the dealership about your original card.
Vmax911 is offline   Reply With Quote
Old 10-13-2015, 09:34 PM   #8
radroach
Drives: car
So I found another owner today and we tried to fix my radio using his SD card. I popped in the card, the screen goes black... and nothing. We tried it several times, and no result. Is there anything that's supposed to happen when I do this?
No idea what to do now, except buy a new radio. This is bullshit and subaru should feel bad for this. No idea how I can argue with my dealership about this, I've went to them before about it 2 years ago and they just stated that my car didn't come with one.
Old 10-13-2015, 10:51 PM   #9
radroach
Drives: car
Is there any procedure I should go by to reprogram the radio? Obviously from my earlier post it didn't seem to work.
Old 10-14-2015, 05:11 PM   #10
radroach
Drives: car
@Vmax911 Ok thanks for the info. Now I know that if the original SD card is lost, the radio will never work again. Nice job on that one, Subaru.
Just got off the phone with the dealership. I listed them the details of what's happened and they heard my concern, but I don't think they feel obligated to fix this problem.
Old 10-14-2015, 06:48 PM   #11
P3tras
Not really. Other original Subaru SD cards should work without issues. But it has to be original one, not just image copy. And of course come from the same type of head-unit.
Old 10-14-2015, 08:01 PM   #12
radroach
Drives: car
Are you sure? Has anybody tested this to make sure? What was the reprogramming procedure?
I tried to use someone else's SD card, I think it was from a 2014 BRZ (I have a 2013), and the screen just stayed black when I inserted the SD card. Different radios?
Old 10-14-2015, 11:17 PM   #13
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Do FRS also have SD card?
Whats navigation difference between FRS and BRZ? Seemed the same to me.
Packofcrows is offline   Reply With Quote
Old 10-15-2015, 07:44 AM   #14
P3tras
FRS and BRZ uses totally different head-units. As I remember FRS does not have SD card, but I am not sure.
Yes, I am sure that different SD card should work. They even sell SD cards separately as replacement (but it cost ~$200...). There were some changes to head-unit in 2014, thus maybe card is not the same
FUJITSU HEAD UNIT SD CARD Bono Electronics | Audio | NAV | Infotainment 6 03-11-2017 10:44 AM
NORCAL BRZ 2015 Navigation - Head Unit, Navi, SD Card $400 lakestreet Audio/Visual, Electronics, Infotainment, NAV 2 11-03-2015 07:23 PM
new head unit mrnibbs Electronics | Audio | NAV | Infotainment 3 06-04-2015 07:58 PM
FS: BRZ OEM Nav Head Unit Griever423 Audio/Visual, Electronics, Infotainment, NAV 2 09-23-2014 03:02 PM
FS: OEM BRZ Head Unit pseudo Audio/Visual, Electronics, Infotainment, NAV 0 12-22-2013 01:02 PM
