Old 10-02-2015, 01:03 PM   #1
Jtbirchfield
Drives: 2014 Scion FR-S
Installed Invidia Overpipe? Bad knocking in the front?
Just installed my Invidia overpipe and have a really bad knocking noise coming from the front on hard acceleration or start up? Any ideas?
Jtbirchfield is offline   Reply With Quote
Old 10-02-2015, 02:35 PM   #2
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Seems like this solution wouldnt be overlooked. But did you tighten all the bolts down? You may not have torqued one down enough and the vibration from the hard acceleration will cause a loose bolt to make that sound.
Kami Speed is offline   Reply With Quote
Old 10-02-2015, 02:57 PM   #3
Jtbirchfield
Yep I just installed the Skunk2 headers and double checked the torque on everything (motor mounts, flange bolts, etc)
Old 10-02-2015, 02:59 PM   #4
Jtbirchfield
It's like you can almost feel it when driving. I don't think it's suspension related and it's only coming from the passenger side right where the overpipe is
Old 10-02-2015, 08:26 PM   #5
zdk554
Drives: black toyota 86 gts
is the overpipe knocking against something?
zdk554 is offline   Reply With Quote
Old 10-03-2015, 12:09 AM   #6
steve99
sounds like overpipe hitting chassis, try removing ftont pipe bolt from mounting bracket then lift btacket so you can put the bolt UNDER the bracket not through the hole and tighten up, this will lift overpie a bit, it that works then drill a new mount hole in frontpipe bracket on car chassis and use nut\bolt with lock washer to mount front pipe
AllStar0419 (10-03-2015)
Old 10-03-2015, 12:25 AM   #7
humfrz
I was going to suggest using a small crow bar and bend that sucker away from whatever it looks like it may be hitting.
Too bad the world ran out of baling wire .....
However, @steve99's suggestion sounds much more better .....
humfrz
Old 10-03-2015, 07:00 PM   #8
Jtbirchfield
I tried your suggestion @steve99. It didnt seem to help at all? I looked at the overpipe while i had it up in the air and it doesnt look like it's touching the subframe. Any other ideas? Will i have to go back to stock overpipe?
Old 10-03-2015, 07:48 PM   #9
humfrz
It may not be touching the frame with the engine not running. However, when the engine is under load it may "torque over" just enough for the pipe to touch the frame.
I suggest you figure which way the engine torques under load, then get under there and try to pull the pipe in that direction, to see if you can get it to come close to the frame.
If so, it’s BFH, crowbar and/or bailing wire time……
humfrz
Ultramaroon (10-04-2015)
Old 10-03-2015, 08:11 PM   #10
Jtbirchfield
Yea F* That @humfrz . I don't wanna have to jerry rig a pipe onto my car. Can you please give me any input on one that doesn't have fitment issues?
Old 10-03-2015, 09:15 PM   #11
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Order perrin motor mounts. It stopped my 3" overpipe from hitting. My engine doesn't wiggle at all...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-03-2015, 09:22 PM   #12
steve99
the engine will move on the mounts during hard acceleration and this usually results in downpipe moving downwards.
sometimes the overpipe hits the frint sway bay especially aftermarket thicker bars
also look if the header ar hitting on the alluminium splashguard or the secondary cat hitting on chassis
or you got a dud overpipe like this guy check yours against stock overpipe, or your header may be proplem even a slight offset or angle difference throws off overpipe allignment
http://www.ft86club.com/forums/showthread.php?t=59400
also see this thread few post down guy had same issue with invida overpipe see photos
http://www.ft86club.com/forums/showthread.php?t=91424
Old 10-03-2015, 09:48 PM   #13
humfrz
Of course, scooter, just put the stock pipe back on.
humfrz
Old 10-03-2015, 11:08 PM   #14
Jtbirchfield
@GsxrMe I might end up doing that.@steve99 I have a Invidia front pipe and wasn't knocking until I replaced the overpipe, even with the stock headers. I reinstalled the oem front pipe and still no good. Everything bolts up no problem, so I am guessing it's just the mounts. There is less than half and inch of clearance between the subframe and the bottom of the overpipe. @humfrz I'd really like to keep an aftermarket pipe on there. I am going to try the Perrin mounts and if that doesn't work I guess I'll just reinstall the OEM overpipe. I was wondering though, does the Perrin overpipe fit any better?
Invidia N1 and / or 3" catted front pipe + overpipe bren5279 Want-To-Buy Requests 1 01-06-2015 12:00 AM
Greddy SP Elite, Unichip , Invidia Front Pipe, T1R Overpipe BC-Boy Canada Classifieds 0 04-16-2014 12:44 PM
Overpipe knocking? Shaun Perry Northern California 17 03-27-2014 11:31 AM
FS: Invidia N1 Titanium Tips, Front Pipe, FA20 Overpipe gdrider77 Engine, Exhaust, Bolt-Ons 6 03-06-2014 12:52 AM
◙◙◙ [NY Local] Invidia Q300 SS tips & Invidia Front Pipe INSTALLED SPECIAL | RAD ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 44 06-07-2013 02:26 PM
