Old 09-30-2015, 04:14 PM   #1
gui dube987
Drives: Frs
tire size for 18x9.5 +35
Hello i'm new here i juste bought a Frs 2 days ago, i looked on the forum to see if the tire i want would fit or rub like crazy but aven't found anything...
So on a 18x9.5 +35 lowered on bc racong extreme drop, will 235/40 rub on the fender or fender liner or ill be alright? If it rub would rolling the fender solve the problem?
Thx
gui dube987 is offline   Reply With Quote
Old 09-30-2015, 04:27 PM   #2
8R6
8R6's Avatar
Drives: FRS
235/40/18 will be almost 20mm taller than stock diameter. even with a slight stretch. depending on what kind of look for, your tire size might change, but i'd go with a 245/35/18 tire and dial in some negative camber.
8R6 is offline   Reply With Quote
Old 09-30-2015, 05:31 PM   #3
gui dube987
Drives: Frs
wouldn't 245/35 rub more than 235/40 since its wider? or no because the diameter is smaller? and would the camber plate + camber bolt be enought camber to make them fit?
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
What size tire should I run? HGaudio Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-18-2015 06:09 PM
Best tire size for 18x9 et 35 TmP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 05-25-2014 10:02 PM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
