Old 09-29-2015, 06:03 PM   #1
datmarktho
Drives: 2013 Scion FR-S Raven Black
Partsam LED Daytime Bulbs?
I just wanted to ask if anyone has used these bulbs to replace their OEM ones
or if it is at least decent
[ame="http://www.amazon.com/gp/product/B00U88LXLE?psc=1&redirect=true&ref_=ox_sc_act_titl e_3&smid=A1B2SF9J2WBIQS"]Amazon.com: Partsam 2x High Power 16-Cree-XB 9005 HB3 9145 80W 6000K Bright White 1370LM Car LED Bulb Daytime Running Light DRL Lamps For 2013 TOYOTASienna: Automotive[/ame]
Just wanted to use some leftover amazon credit and use my prime membership and looked all over amazon. Thanks
datmarktho is offline   Reply With Quote
Old 09-29-2015, 11:32 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
According to a lot of people, for this car, led headlight related bulbs suck because there cutoff is quite bad there's a vendor here that did a comparison to a quality HID kit and the glare on the wall they tested was pretty bad.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Cole (10-02-2015), Diode Dynamics (10-01-2015)
Old 10-01-2015, 12:47 PM   #3
Diode Dynamics
Diode Dynamics's Avatar
http://www.ft86club.com/forums/showthread.php?t=81340
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Cole (10-02-2015)
Old 10-01-2015, 01:28 PM   #4
86Hiro
or Disconnect the module and it gives an aggressive look.
86Hiro is offline   Reply With Quote
Old 10-01-2015, 03:40 PM   #5
FRSBRZGT86FAN
No need to disconnect anything to turn it off in our cars, a bluetooth obdII dongle and the carista app and you can just switch it off in the ECU.
Old 10-01-2015, 04:21 PM   #6
86Hiro
Really? Never knew that, thanks!
Old 10-01-2015, 04:50 PM   #7
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
Does that app give you all the functionality of what like the techstream clone stuff you can buy? I really want to change a few things on my car (seat belt chime, when headlights turn on, and a few others) and if I could just get an app instead of having to buy new hardware, that'd be awesome.
AzureShadow is offline   Reply With Quote
Old 10-01-2015, 09:25 PM   #8
FRSBRZGT86FAN
Pretty much, I haven't used it in a while since I haven't had the stock halogens in a while with the crap DRLs, basically you can disable safety chimes, DRLs, reset ecu if there's a CEL, control auto headlight sensitivity if you have a 2015, how long the lights stay on after the doors are locked etc. It was $20 in the app store when I got it and a quality elm 327 bluetooth dongle was only $5
Old 10-01-2015, 09:33 PM   #9
86Hiro
The app is now FREE, I just downloaded it via App Store
Old 10-02-2015, 08:59 AM   #10
AzureShadow
Awesome, I will pick that up instead of the techstream stuff, should be way simpler.
Their website says customization is a $19.99 in-app purchase, but it sounds like diagnostics are free. I don't have a bluetooth obdII reader to test it out yet though.
Old 10-02-2015, 11:15 AM   #11
FRSBRZGT86FAN
Not free, I ran the beta for the developer for some time, once you are in the car and have the dongle in it will say customization are 19.99
LED daytime running lights sav AFRICA 168 03-22-2016 04:26 AM
FS: OEM side markers + bulbs. OEM turn signal bulbs. akiranakayama Exterior Parts (Aero, Lighting, Etc.) 3 07-29-2015 12:25 PM
10 series daytime LED's razerblaze93 Electronics | Audio | NAV | Infotainment 9 01-22-2015 03:52 AM
daytime Run lights Ryan86 AFRICA 22 02-02-2013 12:39 AM
