Old 09-25-2015, 03:27 AM   #1
Varelco
Drives: '15 GT86 & '22 GR86
Wheels drilled to fit M14?
Hello All,
Need thoughts/advice.
I’m looking at a set of wheels which have been drilled to accommodate M14 sized studs/bolts. Am I able to fit these wheels to my 86 which is M12? Obviously there will be a significant amount of clearance between the stud and the hole in the wheel, but my understanding is that all the clamping force will be on the taper (which are both 60 degrees) and that centre bore supports the wheel (which will centralise it). Is this acceptable to do or is it a no go? The only thing I can think of is the clamping area will be smaller on the taper as the hole is larger (losing 2mm) perhaps using wider nuts would compensate?
Thanks
Matt
Varelco is offline   Reply With Quote
The Following User Says Thank You to Varelco For This Useful Post:
86kahl (09-28-2015)
Old 09-25-2015, 04:30 AM   #2
ryoma
ryoma's Avatar
http://www.ft86club.com/forums/showthread.php?t=95054
take what you want out of it, lol.
Old 09-25-2015, 04:53 AM   #3
Varelco
Thanks mate! Should of searched a bit harder
For those with drilled sideskirts.... Vroomin86 Scion FR-S / Toyota 86 GT86 General Forum 14 05-05-2015 09:34 PM
FS: SP Performance Drilled and Slotted Rotors (2004 STI) Bobblehead Brakes, Suspension, Chassis 4 10-11-2014 03:39 PM
Drilled Holes solution yet? Davesta619 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-20-2014 04:58 AM
WTT: Drilled Mustache for non-Drilled JLMIAMI Exterior Parts (Aero, Lighting, Etc.) 6 07-24-2013 12:24 AM
Power Slot vs Stoptech drilled rotor JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 10-19-2012 12:04 PM
