Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 09-24-2012, 12:51 PM   #1
cnk
Drives: '13 DGM BRZ Limited
Winter setup
Seeing as how the temps have really dropped off this week I'm wondering what everyone plans on doing for their winter rim/tire setup. Personally, I'm debating between getting some 16" steelies and winter tires or spending a little more for some Rota or Motegi rims and winter tires just for aesthetics.
cnk is offline   Reply With Quote
Old 09-24-2012, 12:58 PM   #2
HunterGreene
Hail Magnet
HunterGreene's Avatar
Check to make sure the brakes will fit inside a 16" rim first. Plenty of opinions have already been given on the forum. Just peel back a few layers
Old 09-24-2012, 01:07 PM   #3
engee
Drives: Subaru
16's will fit fine. I will be running 16x7 +50 with Blizzak ws-60's.
engee is offline   Reply With Quote
Old 09-24-2012, 01:24 PM   #4
cnk
Thanks Mr. Search nazi. I already did search and did not find what I was looking for. To quantify this for your imperial regulations, I searched the entire forum using the search word "winter" and have read every post. As with any other forum, if you don't want to post anything constructive, ignore it and move on.
16" steelies will fit. I'm not asking about fitment, I'm asking what others plan on doing now that it's getting closer to winter.
Old 09-24-2012, 01:36 PM   #5
Craig
Craig's Avatar
Drives: Asphalt FRS
Driving my jeep
Craig is offline   Reply With Quote
Old 09-24-2012, 01:40 PM   #6
HunterGreene
Hail Magnet
No reason to get nasty, or even go with the "nazi" moniker. I'm sorry I wasn't able to read your mind and know that you had searched already. In that thread, I'm Jewish, and I take offense to your use of the nazi insult (which, frankly, is ironic, given the circumstance). Killing 10 million people and trying to get people to stop being lazy and do some forum searching are hardly equal.
Maybe I am getting into troll territory here, but frankly, my point still stands:
http://www.ft86club.com/forums/showt...ghlight=Winter (this one was just made, and I had the same reaction to it)
http://www.ft86club.com/forums/showt...ghlight=Winter (this one even has an answer for your 16 inch question)
And the list goes on. I searched the word "Winter" as well and I got 40 threads, 16-17 of them just about rims or tires, and the rest suggesting driving styles, habits, or setting the car up. If I am that insistent on using the , its for a reason.
Old 09-24-2012, 01:58 PM   #7
cnk
OK, let's start over. I asked a question about what folks in this specific regional forum are planning on doing. If you don't have anything constructive to add, please move on. To be honest, not sure why someone from OH is posting in a regional forum for NJ/NY/PA/CT.
I'm sorry if you were offended by the "search nazi" moniker, but if you're not a stranger to forums you should be very familiar with that term and that it is not meant to insult. If you don't have anything else to contribute that specifically answers my question, i.e. what are you going to run this winter, then just move on.
Old 09-24-2012, 02:07 PM   #8
HunterGreene
Hail Magnet
Fair enough. My point was made, though I do consider "Nazi" to be overused anyways...but that's besides the point. And, frankly, with the Atlantic region being so large, you guys are going to see a wide variety of conditions, some of which are similar to the northern Ohio area I am from (ask anyone from Buffalo, Lake Effect snow is a bitch).
I, for one, will be running my old tC rims (same bolt pattern, 17") with the Continental winter tires that I have used for the past 3 seasons. I may consider adding weight to the back, depending on how tail-happy the FR-S is.
Old 09-24-2012, 02:14 PM   #9
cnk
Thanks Hunter. I wasn't even aware that the tC rims would fit. I've been trying to find someone with WRX or stock rims that they didn't want anymore but I can definitely expand my search now. I know steelies will be the cheapest route to go, but I just don't know if I can roll with them as they just look so ugly.
Old 09-24-2012, 02:44 PM   #10
engee
Drives: Subaru
Any 5x100 wheel will fit. Try and keep the offset close to the stock, +48, and you will be good to go.
If you decide to run 16's, be sure to adjust the tire size to compensate for the smaller diameter wheel. 205/55 R16 should work perfectly.
Like I said before, I will be running my old set of wheels from a previous car. They are a cheap pair of wheels off tirerack and I'm running WS- 60's.
Here is a good link to help you sort out what will and will not fit.
http://www.rimsntires.com/specs.jsp
Stock sizes for BRZ:
Offset: +48
Tire: 215/45
That should help widen your selection process as well.
Hope that helps.
Old 09-24-2012, 03:04 PM   #11
cnk
Thanks Engee. I was aware of the 5x100 bolt pattern. Just did not know that the tC used the same bolt pattern and would fit with the right offset.
Old 09-24-2012, 03:15 PM   #12
CBR600RR
Drives: Raven Black
I have Enkei 16x7 with toyo 215/55/16
Old 09-24-2012, 03:49 PM   #13
Foobar
SLO NO MO
Foobar's Avatar
Putting Michelin Primacy Alpin PA3's on my stock rims, keeping the stock size of 215/45R17.
Come Spring, I'll be looking for a lightweight set of 17x8 rims and putting 245/40R17 summers on em.
Old 09-24-2012, 04:02 PM   #14
HunterGreene
Hail Magnet
Offset: +48
Tire: 215/45
Hope that helps.
Ok, now I am worried, the offset for the tC wheel is +45, which is fairly close to the +48 of the FR-S. Anyone wanna chime in if the 3 mm will make a difference?
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
Brz Drag Setup Tansey86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-12-2012 11:24 AM
Offset help for staggered setup JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-24-2012 01:46 PM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
