Old 09-13-2015, 12:08 PM   #1
subiebui
Drives: 2017 STi WRB
Whiteline roll center and bump steer kit concerns
Hey, so I just put in the white line roll center kit and after I got done doing the alignment I went for a test drive and noticed the steering doesn't like to come back to center. When I was putting the ball joints in I did notice they were really stiff to begin with. Does anybody know if they need to break in or is this a normal condition for this set up? I'm on rce tarmac 2 coilovers lowered about an inch and some front and rear. Alignment specs weren't unusual. Thanks for any help
subiebui is offline   Reply With Quote
Old 09-13-2015, 01:06 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Do you have anything adjusting caster? It might have been installed wrong, reducing caster instead of increasing it, which would result in the symptoms you described.
Old 09-13-2015, 01:54 PM   #3
twag4
Drives: frs
You should also consider the Whiteline kit KCA434, anti dive/caster correct kit. Perrin also makes one, but it is much more expensive. It is called the positive steering response system.
twag4 is offline   Reply With Quote
Old 09-13-2015, 02:06 PM   #4
subiebui
I have the rce street camber plates which added caster. I'm around 6.2 degrees caster if Im remembering correctly
Old 09-13-2015, 02:09 PM   #5
subiebui
I didn't mess with the caster since my last alignment. The camber plates added a little bit . all I adjusted was toe and pulled the front camber from -3-3.5 to -2.5 on both sides
Old 09-13-2015, 03:21 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
My balljoints didn't even fit my car, Whiteline blamed my LCA from the factory or how it installed, even though we did it was the right balljoint tool, etc.
It sounds like your ball joints aren't settling, when a ball joint is bad, you get that feeling of the steering wheel not wanting center by its self. However, i dobut the ball joints are shot. Did you install them with a proper ball joint tool? Or did you hammer it in the Honda way? It could be an alignment though.
Let us know.
Old 09-13-2015, 03:47 PM   #7
subiebui
Let us know.
The ball joints were really stiff out of the box when I was playing with them before I installed them. I pressed them in the the proper tools on a press at the shop
Old 09-13-2015, 05:55 PM   #8
Calum
That Guy
It's not uncommon for a ball joint to be too stiff to move by hand, straight out of the box. It's hard to tell how stiff they were from text. They certainly could be the issue, but before I come to that conclusion I'd like to make sure it isn't something else.
Can you post your full alignment specs?
What kind of camber plates do you have? When were they installed? Can you post a pic of them to show their orientation?
Old 09-13-2015, 07:55 PM   #9
subiebui
The ball joints were stiff to the point i couldnt move them by hand at all. I didn't print the alignment but off the top of my head its: front camber, both -2.5, 0 toe, 6.2 degrees caster. rear toe 0, -1.9-2.0 degrees camber both sides. i've only had the race comp engineering tarmac 2 and race comp camber plates installed for about a thousand miles and didnt have any issues before doing the roll center and bump steer kit. i haven't heard any pops/clunks or noticed any binding. I drove the car for a good bit today and it seems to be getting better? but it might just be in my head.
Old 09-14-2015, 03:20 PM   #10
Calum
That Guy
Then yeah, I'd have to agree it's the whiteline parts.
Old 09-16-2015, 01:02 AM   #11
subiebui
Sad face. Well I'll probably end up bringing it in and checking out everything again. I've emailed white line but haven't gotten any response from them yet
Thanks for the help everyone
DIY: Whiteline Roll Center Adjustment Kit Install RallySport Direct DIY (Do-It-Yourself) Guides 27 05-27-2020 07:21 AM
(PA) Whiteline roll center/ bump steer tapsumbongfrs Brakes, Suspension, Chassis 2 03-05-2015 04:12 PM
Whiteline Bump Steer & Roll Center Kit Review troek Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2014 09:25 AM
Whiteline Roll Center/Bump Steer Correction Kit! MAPerformance Brakes, Suspension, Chassis 3 10-23-2013 10:24 AM
Whiteline releases their roll center/bump steer correction kit for the BRZ/FRS! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 10-15-2013 05:57 PM
