Old 09-12-2015, 04:50 PM   #1
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
D00D Cal ID question
I'm doing the cold crank pulse width adjustments from the below link
http://www.ft86club.com/forums/showp...1&postcount=40
It talks about 0'ing out the IPW comp A table. Mine is already 0'ed out with a D00D ID but I was talking to another member on the B01D ID who has different values for the cells.
Does anyone know if this is correct? I made sure I have the correct XML definition file loaded. This is off of the 2.068 OFT maps. From what I can see as well the 2.066 map that I am currently running with no issues outside of cold starts has the table 0'ed out as well.
The below table is the stock 2.068 map just with the 1.2, 1.25, and 1.3 multipliers added to the a-f tables. I have not edited the IPW comp A at all.
Any input is appreciated!
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
phrosty (09-12-2015)
Old 09-12-2015, 07:12 PM   #2
steve99
Attachment 120039
Sometimes their are minor changes between roms or rom calid types or its just a cut\paste error, see what is a stock rom.
you tables look ok
wayno has done more work on those cranking tables i would grab his tables from one of the roms in his tune thread they will work better. will update the tune tweaks thread.
Tectoniic (09-12-2015)
OFT E85 question apelpapa Software Tuning 3 08-31-2014 12:46 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
A/C question radroach Scion FR-S / Toyota 86 GT86 General Forum 6 06-13-2014 06:17 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
Almost there.....but question VENOM~ CANADA 25 08-22-2012 06:39 PM
