Old 09-11-2015, 04:00 PM   #1
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Brake pad still can use for track?
I use this project mu club racer for two track days and in the last session I feel the brake pedal became soft, before I think my brake fluid got air in it, but when I change back to my street pads( ferodo ds2500) I didn't feel that and I saw my club racer like this in pic, is this still can use? My brake fluid is endless 650 Name:  ImageUploadedByTapatalk1442001602.625638.jpg
ZHoward is offline   Reply With Quote
Old 09-11-2015, 04:39 PM   #2
Stop using ABS.
You can keep using that pad.
wparsons (09-11-2015)
Old 09-11-2015, 06:39 PM   #3
ZHoward
ZHoward's Avatar
Stop using ABS.
LOL.. I didn't feel ABS... Maybe next time I will try carbotech xp10
Old 09-11-2015, 06:48 PM   #4
Just because you aren't feeling it, doesn't mean you're not using it.
Your pad clearly shows overheating, and your other posts indicate to me that you're a novice, and 99% of the time, this means you're using ABS, which causes your brakes to overheat, massively, and quickly.
wparsons (09-11-2015), ZHoward (09-11-2015)
Old 09-11-2015, 08:02 PM   #5
wparsons
wparsons's Avatar
XP10's are rated for basically the same temperature range as the club racers, so I wouldn't expect anything different.
What tires are you running? How long are the sessions you're running?
flickr
Old 09-11-2015, 08:04 PM   #6
ZHoward
ZHoward's Avatar
Federal 595rsr and 5 session in streets of willow in SoCal and over 100F all day
Old 09-12-2015, 07:52 AM   #7
wparsons
wparsons's Avatar
How long are the sessions though? That's MUCH more important than how many you run in a day.
flickr
Old 09-12-2015, 10:19 AM   #8
ZHoward
ZHoward's Avatar
20 mins
Old 09-12-2015, 12:31 PM   #9
wparsons
wparsons's Avatar
If you're overheating club racers in 20 minutes on those tires, I would suspect it's something in how you're driving. Either ABS, or dragging on the brakes for too long every braking zone (vs a short hard brake application).
flickr
Old 09-12-2015, 04:55 PM   #10
ZHoward
ZHoward's Avatar
In the last session, so it is about 80mins already
Old 09-13-2015, 08:58 AM   #11
wparsons
wparsons's Avatar
Unless they're 20 minute sessions back to back, the brakes are fully cooled by the next session...
flickr
The Following User Says Thank You to wparsons For This Useful Post:
ajc209 (09-14-2015)
Old 09-14-2015, 10:00 AM   #12
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
It looks like somebody hates to admit that his skill level might be the culprit.
Come on. It's nothing to be ashamed of nor do you need to make any excuses. You just need to have plenty of seat time with an attitude to learn from anyone and everyone. Everyone has to start from somewhere!
I am not ashamed to admit that I'm a noob and have too much to learn
Rookie84 is offline   Reply With Quote
Old 09-14-2015, 10:40 AM   #13
GT86_PRAGUE
Drives: GT86
Is there a simple way how to switch ABS on/off? Also same question for airbags.
GT86_PRAGUE is offline   Reply With Quote
Old 09-14-2015, 01:57 PM   #14
Pull any wheel speed sensor or the fuse.
Pull the fuse for airbags.
GT86_PRAGUE (09-15-2015)
Track day brake life? transition Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-03-2014 04:57 AM
How to restore OEM brake pads after a track day? torqdork Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-24-2013 12:45 PM
Brake issues on the track Mike @ MRP Tracking / Autocross / HPDE / Drifting 28 08-30-2013 04:03 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
BRZ and FR-S Street and Track Brake Products available now JRitt Brakes, Suspension, Chassis 3 07-31-2012 09:37 AM
