Old 09-10-2015, 12:38 PM   #1
kingkenny
Drives: 2014 Toyota GT86
Tein SRC parts no ?
I just receive a set of Tein SRC , but the compression and rebound adjustment is not 16 click , is 30 click !!
Also the parts no is different than DSQ54-81LS1 !!
Just want to know what is the different !!!
kingkenny is offline   Reply With Quote
Old 09-10-2015, 03:21 PM   #2
Can you forward me your purchase invoice so I can verify that you ordered the right part from us?
You're posting individual damper part numbers, and that part number is correct, and judging from the pictures, you have the correct parts elsewhere too.
kingkenny (09-10-2015)
Old 09-10-2015, 04:57 PM   #3
kingkenny
Thanks for help , so it is the right parts !?i order the parts from Japan , when i have it install , i turn the bottom and top , getting 30 click ....
Is it weird ? I will have it check again , and use the adjuster and see if is it me counting it wrong !!
Old 09-10-2015, 05:11 PM   #4
I'm sorry, but I'm not familiar with the current JDM spec Tein SRC. You'll need to ask your vendor for support, as I have no knowledge of your dampers. Additional clicks are rebuild overhead; do not go past 15 clicks from maximum damping, or you may damage your damper.
Old 09-10-2015, 07:11 PM   #5
kingkenny
Problem solve ! It is dead click !!
Old 09-10-2015, 09:01 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Yup. Common, though I didn't know till now it was rebuild overhead. I haven't even tried to see how many clicks I can get. In fact, I had one adjuster come off in shipping, and the actual adjustment seems to have no inherent stops.
Enjoy.
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
All Cusco, KW, and Tein Parts at Absolute Lowest Prices IslandImportPerformance Brakes, Suspension, Chassis 10 06-14-2012 08:34 AM
TEIN releases more FT-86 Suspension parts! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-07-2012 01:20 PM
