Old 09-09-2015, 04:33 AM   #1
KenTK808
Drives: White 2014 Scion FRS
Rear toe adjustment question
Bought older set of rims that had unknown offset. Had to run a 5x100 to 5x114 conversion spacer (15mm). After I put the rear rims on, it is a little too aggressive. It rubs fender on bumps. I need the negative camber to fit them. I lowered the car about 2 inches on Fortune Auto 500 series coil overs. I have PBM rear lower control arms. How much toe adjustment is there on the stock arms, or is there none? I have an alignment appointment in the next couple days, should I buy adjustable toe arms or are they not necessary?
KenTK808 is offline   Reply With Quote
Old 09-09-2015, 08:37 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Should be enough range with the stock setup.
Old 09-09-2015, 06:34 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I thought the oem toe arms weren't adjustable.
You should get adjustable toe arms if you want to get your alignment done correctly.
Old 09-09-2015, 06:41 PM   #4
PradiG
Drives: Fr-s
the oem toe arms are adjustable up to roughly -5 camber. Anymore more and you will need aftermarket toe arms.
PradiG is offline   Reply With Quote
Old 09-09-2015, 06:51 PM   #5
Captain Snooze
Drives: Red Herring
Sorry, I'm a little lost here. I thought toe arms adjust toe and lca arms arms adjust camber. Also, adjusting camber alters toe so one needs adjustable toe arms to get the toe right with camber alterations.
Oem toe arms
Old 09-09-2015, 07:19 PM   #6
PradiG
Drives: Fr-s
Oem toe arms
Attachment 119847
Attachment 119857
What i meant to say what that the toe can adjust to compensate for up to -5 degrees of camber coming from the lca.
i didnt meant he toe adjusts the camber.
Old 09-09-2015, 07:29 PM   #7
redlined600
redlined600's Avatar
Drives: Fr-s
Oem toe arms
Attachment 119847
Attachment 119857
The stock toe arms attach to the car via eccentric bolt, thus adjustable albeit a limited range.
The Following 2 Users Say Thank You to redlined600 For This Useful Post:
Captain Snooze (09-09-2015), Purist (07-31-2020)
Old 09-09-2015, 07:33 PM   #8
KenTK808
Thank you for the info! very helpful
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 09-12-2015, 04:49 AM   #9
KenTK808
Just as a reference for everyone. PBM LCA require you to notch part of the subframe so you can get a cess to one of the lock nuts. This is a big design flaw. I wouldn't buy them.
The Following User Says Thank You to KenTK808 For This Useful Post:
ssyed (04-17-2017)
Eibach Pro-Kit Camber adjustment & tire question JMOrem Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-07-2014 03:02 PM
Toe adjustment question TylerLieberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-24-2013 10:20 PM
BC BR Coilover adjustment question. HATED1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-12-2013 12:59 PM
Quick Question when doing clutch Adjustment Number 6 BRZ First-Gen (2012+) — General Topics 3 03-13-2013 11:18 PM
Quick Question when doing Clutch Adjustment Number 6 Scion FR-S / Toyota 86 GT86 General Forum 2 03-09-2013 04:31 PM
