Old 09-07-2015, 11:11 AM   #1
GT86_PRAGUE
Drives: GT86
Question Anyone using close ratio gears?
Has anyone been using close ratio gears?
I have 4.67 FD, upgrading to 4.88 this week (just arrived). I did some local autocross and 4.88 will probably be too much (I run 95% on 2nd, downshift to 1st twice and to 3rd twice during one lap), so will these gears help me?
N/A MT
GT86_PRAGUE is offline   Reply With Quote
Old 09-08-2015, 12:05 AM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The MT box already has close ratio gears.
If you're talking about FD only, you need to get the terminology correct.
https://docs.google.com/spreadsheets...it?usp=sharing
Old 09-08-2015, 12:08 AM   #3
matthewdesigns
Drives: '92 Miata (turbo)
Have a look at some online gearing calculators, you can enter your gear ratios, max rpms, and final drive ratio to come up with a mph/kph conversion for each setup. Here's one for example: http://www.apexgarage.com/tech/gear_ratios.shtml This one is not graphing, but there are some out on the web that do comparative graphic overlays. You can then compare this info to any data collected on track and it can help you determine if you can save a shift or two along the way.
Edit: What are the chances...nice link!
matthewdesigns is offline   Reply With Quote
Old 09-08-2015, 12:54 AM   #4
Turdinator
Señor Member
Turdinator's Avatar
Cusco make a closer 1st and 2nd gear making them both taller.
OP it would counteract some of your FD change and probably mean you'll be changing gears more often. Depending on the course, the cars setup and your driving it may or may not be quicker.
1974 TA22 Celica
2013 86 GT
Old 09-08-2015, 01:52 AM   #5
GT86_PRAGUE
Drives: GT86
I definitively need closer 3rd (to accelerate faster at long straights) and longer 1st (it is too short even now with 4.67 FD). I am quite happy with current 2nd.
So close gears (like Cusco) will help me with 1st (specially after 4.88 upgrade), 4.88 will help me with 3rd and it may or may not screw up 2nd (depending on track). Right?
CUSCO 1st: 2.946, 2nd: 2.011
REVOLUTION 1st: 2.907, 2nd: 1.988
OEM 1st: 3.626, 2nd: 2.189
According to ratios, 1st and 2nd will become longer, right?
Edit:
Where is the engineer when you need him?
If I did the math right after 4.88 upgrade
1st should be +- same length as OEM (0.46% or 1.54% for Revo longer) but revving 18.29% faster
2nd should be 10.16% (9.11% for Revo) shorter and 18.29% faster
3rd should be same but 18.29% faster
Compared to current 4.67 setup I will gain:
1st: 14.36% (15.44% for Revo) longer gear, 4.39% faster
2st: 3.74% (4.79% for Revo) longer and 4.39% faster
3st: only 4.39% faster
Old 09-08-2015, 01:53 AM   #6
GT86_PRAGUE
Drives: GT86
So you dont have it, because you would know.
Cusco makes one, so do Revolution or Autofactory (probably just rebranded stuff).
Old 09-08-2015, 02:14 AM   #7
GT86_PRAGUE
Drives: GT86
Thanks, but I dont have capabilities to gather that kind of data.
Edit:
I am more concerned about rpm than speed, because I dont want to hit rev limiter.
I think I am between 4k and 5k most of the time, but again, no logs or time to observe.
Old 09-08-2015, 08:01 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I sometimes wonder what is the reasoning for such short stock OE 1st gear.
Old 09-08-2015, 09:50 AM   #9
fika84
fika84's Avatar
Edit:
All data needed can be found on this website (for gear ratios, and you already know your final drive), except the tire diameter in which you can put that info in here to get the diameter (LINK)
And if you're worried about RPM, then put in the RPM that you DON'T want to be at and it will tell you the speed.
fika84 is offline   Reply With Quote
Old 09-08-2015, 10:09 AM   #10
GT86_PRAGUE
Drives: GT86
The thing is, I dont have data collected on track. I dont have time or equipment to do that. I know about these calculators, but without these data I cant solve anything. I can only calculate this relatively which I tried few posts ago.
I have 215/45R17, 4.67 FD. I dont have any data from track and track is different every run (cones on windy airport strip).
Old 09-08-2015, 10:55 AM   #11
fika84
fika84's Avatar
Oh ok, now I'm on the same page. You don't know what speeds you're currently running at.. If you know the RPM that you currently run at, you can go backwards and get the speed to be able to compare it to the calculators.
Old 09-08-2015, 11:09 AM   #12
GT86_PRAGUE
Drives: GT86
Yeah, but I dont have time (skill) to observe speedo while driving.
Anyway, for my purposes I dont need anything NASA approved, I just wanted to know if the Close Gear set (lets say Cusco) will/should help me or not. It is not cheap and nobody has it.
After 4.88 upgrade, I would have even shorter gears (I will be shifting more), so this Cusco set should fix gear length more to original setup while maintaining faster revving (more torque). Right?
Old 09-08-2015, 11:25 AM   #13
fika84
fika84's Avatar
Sounds about right to me. What differential did you switch to? Or did you keep the MFactory?
Old 09-08-2015, 11:43 AM   #14
GT86_PRAGUE
Drives: GT86
I have Mfactory 1.5/2W (it was not affected by the crash, the guys was very suprised with that behaviour and as every other mech thought it is broken, but it was just very tight/heavy - not for 200hp), currently on much lighter setup with 3 lamels. I dont know more details now, but I will get them.
I am very happy with current setup, I only thing guys set it up more to 1.0 than 1.5, because there is zero kick/slide on downshift while braking. This is the only thing I will change with 4.88.
Rear end ratio and ECU changes? mid_life_crisis Software Tuning 12 01-21-2015 02:14 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
