Old 09-07-2015, 12:03 AM   #1
boomslang
Drives: Toyota
My custom gauge plate to replace the radio
I wanted to install some quality gauges and didn't care about my radio.
So I use the JDM TRD gauge plate brackets along with making a custom stainless steel gauge holder plate....squeezed in four Spek 52mm gauges.
These gauges are pretty sweet compared to the typical low buck gauges that you see rebranded all over. The Speck gauges have peak memory, high warnings, low warnings, and can even low-side trigger a relay when a warning is issued. You can also change the illumination color & brightness, as well as change the needle brightness.
boomslang is offline   Reply With Quote
The Following 5 Users Say Thank You to boomslang For This Useful Post:
DAEMANO (09-07-2015), GotBRZ1691 (09-07-2015), Panman (09-07-2015), RT-BRZ (12-01-2024), SlammedSilly (09-22-2015)
Radio block off plate? Mil_Gates Electronics | Audio | NAV | Infotainment 17 01-14-2022 07:47 AM
Custom gauge pod (52mm) Fizz Australia Classifieds 2 12-01-2015 07:58 AM
Custom Gauge Cluster? Ingen Cosmetic Modification (Interior/Exterior/Lighting) 34 07-03-2014 10:41 PM
Custom Voltmeter Gauge Install on my FR-S Carban DIY (Do-It-Yourself) Guides 7 05-10-2014 07:47 PM
Replace the speedometer for a gauge TIE Pilot Electronics | Audio | NAV | Infotainment 11 10-03-2012 09:19 AM
