| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
Waited 5 years for this
Drives: '18 MX-5 Club
Evo: GT86 VS MX-5
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | Mr.Impreza (09-08-2015) |
Drives: FRS
Cool. Thanks.
Interesting data in this video about the new Miata giving up time to the GT86 on the straights.
C&D just had its annual Lightning Lap at VIR. The new Miata was more than 2 seconds slower than the BRZ. ND Club-Spec Miata @ 3:20.8 vs. BRZ @ 3:18.6. I think the data is showing that the Twins will be faster at longer tracks (e.g., VIR), and the ND Miata will be quicker at tighter/twistier tracks (e.g., SOW).
2022 BRZ Build 2013 FR-S Build |
| The Following 8 Users Say Thank You to DarkSunrise For This Useful Post: | akyp (09-16-2015), Entroper (09-07-2015), hmong337 (09-10-2015), JS + BRZ (09-08-2015), pinski (09-23-2015), Sigh-on-Rice (09-05-2015), strat61caster (09-05-2015), ZHoward (09-05-2015) |
#4 | |
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | DAEMANO (09-06-2015) |
Drives: 14' firestorm
#7 | |
The Twins are probably making up ground towards the end of straights where they can stretch their legs and use their aero advantage.
#8 | |
I like this comparison the best so far, very positive on both, less negative on one over the other in any category.
Highlighted the biggest detriment of the 86 for me stock, the built-in understeer and I'm glad to hear praise for the ND's engine, I was a little worried that the SkyActiv would fall flat. Quote:
Drives: series.blue
I'm saying both cars are awesome, and if you put them both on the exact same tires the results are going to be identical. Every one of these comparisons have been close enough to point to the tires being the only real difference. The lighter weight of the miata is gigantic and helps in tighter corners and tracks but it doesn't look like it makes more of a difference than the difference of the tires.
The fact that C&D actually had the BRZ lapping faster than the Miata is surprising and it points to the BRZ engine is better and that the tires are a gigantic weakness. People that laugh at pointing to the tires are living decades ago, tire technology is truly amazing, and the right tires can make even the worst car handle really well. |
#10 | |
Skip to 6:00 to get to the point, note that the S04's tested are listed as performance tires, the S001's spec'd as OEM on the new MX-5 (same tire around the world so as tested in the UK as well) are listed as low rolling resistance per Tirerack. [ame="https://www.youtube.com/watch?v=FSqWD5BSeoY"]Testing Tires with Subaru BRZ, Ford Mustang & BMW 328i! The Downshift Ep. 65 - YouTube[/ame] Yup the tires would have put them neck and neck in this EVO test for sure, but the Miata has 83% of the weight and ~95% of the engine of the 86 and as mentioned in every video a much more competent suspension setup off the showroom floor (double wishbones give it a noticeable advantage in front end grip as explicitly called out in this video that the 86's front end is lacking in comparison). Tires won't overcome that in a test of handling as shown above where the 86 is on similar rubber to what the ND comes spec'd with (actually bigger rubber at 215 vs 205) and only get marginal improvements. The Primacy's are seriously underrated. |
#11 | |
| The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | Entroper (09-07-2015), strat61caster (09-06-2015) |
#12 | |||
"Max Performance" Tire also includes the MPSS (which can give some 'extreme's' a run for their money), you're right there are great tires and mediocre tires in every class, most people who care aren't futzing around with ~300TW options so it's hard to guage where the S001's fall in line, but the fact is that Bridgestone calls that a LRR tire and the S04 description babbles on about performance applications... Edit: http://www.tirerack.com/tires/tires....+Pole+Position Quote:
#13 |
Time Traveller
Watching the video a few notes:
The cars as equipped for the test were essentially a draw at the track. The MX-5 is absolutely tiny inside with the top up and that body roll, wow. It was also noted that the Miata was optionally equipped with an LSD. The presenter made a very clear point that the GT86's Primacy's contribute to it's both its' under and oversteer. In his words: "the tires are made for sliding". "The GT86 will maintain a slide in a way the Miata will not". "The MX-5 will also slide around but you can't do it on power alone".Most importantly the conclusion at 9:10: "In the end just one tenth of a second separates the two cars. The MX-5 may be 40 horsepower down on the GT86, but it's much lighter and it has grippier tires. So the Mazda is the faster of the two just, but the GT86 was more fun. "If the MX-5 gets an optional LSD upgrade then equal tires should be considered for the GT86 which would obviously make the 86 quicker at probably any track than this Miata. |
#14 | |
It could be that the RE050A's are much stickier MP tires than the S001 and S04PP.
| The Following User Says Thank You to DarkSunrise For This Useful Post: | strat61caster (09-06-2015) |
| H6 GT86 | radroach | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-20-2013 03:37 PM |
| WRC Car: TMG GT86 CS-R3 | riyal | AFRICA | 8 | 11-19-2013 02:03 PM |
| GT86 OEM Option Pin Stripes (anyone done this to their 86/GT86/FRS/BRZ)??? | jbsali | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-28-2013 11:10 PM |
| BRZ + GT86 | mackeye | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 03-30-2013 06:35 PM |
| MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) | RadOnc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-23-2012 08:42 AM |
