Old 09-04-2015, 12:09 PM   #1
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
Cutting up the vortex generator (roof fin) to fit the BRZ shark fin antenna
I just bought a vortex generator that'll fit the OEM mast antenna for cheap, so I can make the hole bigger to fit the shark fin antenna that came with my BRZ.
I'm wondering how I can go about this for best craftsmanship? I'm guessing going to a body shop would be the best way to go, does anyone have any experience with modifying ABS plastic?
Thank you for any help!
chezzy79 is offline   Reply With Quote
Old 09-04-2015, 12:10 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Could you just remove then re apply the shark fin?
Old 09-04-2015, 12:22 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
He has a shark fin. The vortex generator they make for the frs/brz is shaped to fit the oem antenna. He wants to modify the vortex generator to fit around the shark fin. The shark fin antenna base will be larger than the oem as it literally sits on top.
Old 09-04-2015, 12:40 PM   #4
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
I would, but that will probably look horrible since the shark fin probably will stick out a bit and I doubt it'll sit flush.
Old 09-04-2015, 12:41 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Good points haha!
Old 09-04-2015, 05:43 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Dremel with a sanding drum
Remove very small amounts at a time
Test fit every two seconds
Send donation to my paypal account
Old 09-08-2015, 12:00 PM   #7
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
I thought about getting some dremel with a sanding drum, since it's probably not gonna go very well with a hacksaw and sandpaper.
I was looking if anybody has any idea where I can get this done professionally, but anyone?
Old 09-08-2015, 04:44 PM   #8
ryoma
ryoma's Avatar
do vortex generators work on this car? or is it for looks? I definitely want to see pictures though after you fit it. I remember reading that roof spoilers are actually more bad than good for our car. I'm wondering if it's the same for the vortex generator
Old 09-08-2015, 08:32 PM   #9
Poodles
Drives: 2015 Series.Blue
http://www.nytimes.com/1981/11/15/ny...oor-tiles.html
It's kind of a crappy write up, but it should give you an idea of what you need to do to trace the contour. Once you have that, you can easily overlay it over the part and find out where it needs to be modified.
Old 09-10-2015, 10:51 AM   #10
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
Thanks for the suggestions so far, I got a perspex cutter, hot knife, and a tile-cutting bit for power tool (as well as a fine grit dremel) to see which one will work the best.
My plan is pretty simple:
1. Take off the OEM antenna and trace the outline on the vortex generator
2. cut the outline with whatever works the best
3. sand the edges of the widened hole to smooth it out
4.????
5. Profit!
ABS VORTEX GENERATOR bandit0289 Exterior Parts (Aero, Lighting, Etc.) 10 10-13-2015 11:43 AM
WTB: Vortex Generator (Roof Fin) that fits shark-fin antenna, unpainted chezzy79 Want-To-Buy Requests 0 08-29-2015 09:05 PM
front vortex generator mokinbird87 Cosmetic Modification (Interior/Exterior/Lighting) 4 05-19-2015 07:16 PM
DIY: Rexpeed Vortex Generator kalamitykode DIY (Do-It-Yourself) Guides 4 05-28-2014 04:15 AM
GT86 Vortex Generator kalamitykode Cosmetic Modification (Interior/Exterior/Lighting) 2 04-25-2014 11:03 AM
