Old 09-02-2015, 04:52 PM   #1
Yoda
Drives: Crystal Black BRZ(Sophia)
Windows 10 And Open Flash Manager
I will be picking up my OFT today and will be installing the OFM (Open Flash Manager). I see on the website there is a patch to run the OFM with Windows 8 that is required but does anyone know if it will work for Windows 10?
I am kinda new to this whole tuning thing and hope to fine tune the OFT myself. So much information for me to dig through
In case you are wondering I am installing the Gruppe UEL header tonight with the OFT and running 93oct down here in Florida. Everything else stock.
Yoda is offline   Reply With Quote
Old 09-02-2015, 04:56 PM   #2
DarkSunrise
DarkSunrise's Avatar
I had to run Open Flash Manager in Win 7 compatability mode in order for it to work in Win 10.
Right click, properties, compatability tab, Win 7 compatability box and run as admin.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Jyn (09-02-2015), NyC Zn6 (09-02-2015)
Old 09-02-2015, 05:05 PM   #3
DAEMANO
Time Traveller
Weird, I ran Open Flash Manager normally on both my Win 10 desktop and 8" Winbook tablet. No compatibility modes needed. Go figure.
Old 09-02-2015, 05:44 PM   #4
Yoda
Yea just wanted to double check because on the website they warned there could be a checksum error when uploading files. I deal with enough IT issues at work and rather not have to come home and work some more lol.
Old 09-02-2015, 06:15 PM   #5
wparsons
wparsons's Avatar
I would run the patch, just in case. It's a C++ redistributable patch, so chances are you'll need it under 10 as well.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Yoda (09-02-2015)
Old 09-03-2015, 12:04 AM   #6
DriftHappens
Drives: '14 FRS White
on my upgraded 7-10 i didn't run the win8 patch. OFM works just fine. on my surface pro (win8-10) it had the patch alrady, works fine. Either way, i have it on two win10 boxes, so you'll be fine.
DriftHappens is offline   Reply With Quote
Old 09-03-2015, 12:57 PM   #7
wparsons
wparsons's Avatar
The patch is only if you're uploading new tunes to the OFM, so the checksum is corrected properly. If all you did was open OFM, that isn't a sign it's actually working.
flickr
Old 09-03-2015, 08:42 PM   #8
DriftHappens
I should have clarified, I've adjusted tunes downloaded/uploaded to oft, from both machines with win10.
The Following User Says Thank You to DriftHappens For This Useful Post:
wparsons (09-04-2015)
Old 09-04-2015, 04:53 PM   #9
Yoda
So I finally flashed my car with the stage2 UEL 93 tune and I am a bit underwhelmed. There is a bit of lag or delay in the throttle. I read that I may need to drive it for awhile to let it relearn the throttle position but not sure how long. I thought maybe I had an exhaust leak but the LTFT are steady at -1.56 at idle with no crazy +/- 10 variation while driving. Anyone has any input or should I just give it a week to see if the OFT starts doing it thing?
Old 09-04-2015, 08:53 PM   #10
phrosty
Next time you drive, first put it into ON without starting engine, and depress the pedal all the way and back up 10-15 times. It should help a lot with the dead pedal. Otherwise, it will fix itself over a few days time.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Yoda (09-04-2015)
Old 09-06-2015, 02:46 PM   #11
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
I stay with windows 7 for all my programing and hacking needs.
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 08-30-2019, 09:22 PM   #12
InstaGib
Drives: 2015 Scion FR-S || Raven Black
Most of us have the same issue. This is common on cars with drive-by-wire.
Turn the car on, but don't start it. Then press the throttle pedal down to WOT 20-30 times. Turn the car off, then repeat. The throttle body will now have its learned positions, and should resolve the problem.
For anyone in this thread looking for info on compatibility with OFT and Win10, I ran the utilities using administrator rights and had no issues. I loaded a tune from the OFT website onto my tablet, and flashed it. I have not yet used romraider in Win10.
InstaGib is offline   Reply With Quote
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
*Auto* Light from windows flash on driver's door Walla Walla Issues | Warranty | Recalls / TSB 7 12-05-2013 01:09 PM
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 04:33 PM
Is there a way to open/close the windows with the key fob? Zoti Electronics | Audio | NAV | Infotainment 12 09-20-2013 12:43 AM
