Old 08-27-2015, 02:35 PM   #1
lupindub
Drives: Scion FR-S
For the life of me, I can't seem to disconnect the 3rd brake light.
This little wire connecting the 3rd brake light I want to disconnect but for the life of me I can't seem to get it un-hooked. It seems like it should be pretty easy but mine seem to be stuck. Anyone have a video or can explain how to unconnect this thing?
lupindub is offline   Reply With Quote
Old 08-27-2015, 02:42 PM   #2
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Are you trying to disconnect the item from the body of the car or just from the plastic connector?
Old 08-27-2015, 02:50 PM   #3
lupindub
Drives: Scion FR-S
I am trying to disconnect the plastic connector shown in the picture.
Old 08-27-2015, 06:04 PM   #4
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Yes, that connector is in the trunk, underside of package shelf.
You simply must push in, from the side of connector (towards the center of the connector) on what appears to be (yet is not) two tiny prongs of white plastic. You must push in thoroughly to get it to unlock. Once unlocked, the two halves of the connector pop apart easily. I simply used the fingernail of my smallest finger.
a tiny screwdriver would do also...toothpick...point of a pen, etc.
Note: there is no double lock (as on some cars) for this connector...just one...what you see.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
humfrz (08-28-2015)
Old 08-27-2015, 10:29 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
i shoved a flathead 'precision screwdriver' in there to release it
lupindub (08-28-2015)
Old 08-27-2015, 10:57 PM   #6
jblmr2
jblmr2's Avatar
Why are you trying to disconnect it? It's a safety device that is mandated by law.
jblmr2 is offline   Reply With Quote
Old 08-27-2015, 11:07 PM   #7
Impureclient
Drives: 2015 FR-S
[ame="https://www.youtube.com/watch?v=b5s9lMzMhAU"]https://www.youtube.com/watch?v=b5s9lMzMhAU[/ame]
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
justin6280 (08-28-2015)
Old 08-27-2015, 11:39 PM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Scissors. Cut and splice.
Packofcrows is offline   Reply With Quote
Old 08-28-2015, 09:08 AM   #9
lupindub
Drives: Scion FR-S
This did the trick, thank you.
Old 08-28-2015, 09:09 AM   #10
lupindub
Drives: Scion FR-S
There is a loose piece of plastic making some un-godly rattling noise inside of the third brake light. I am trying to disconnect it and safely remove said plastic piece.
The Following User Says Thank You to lupindub For This Useful Post:
jblmr2 (08-28-2015)
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
OEM Brake Pad Life Cal3000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-03-2014 06:39 AM
Track day brake life? transition Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-03-2014 04:57 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
Brake Fluid shelf life? VoiD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-02-2013 06:17 PM
