Old 08-27-2015, 01:18 PM   #1
lupindub
Drives: Scion FR-S
What purpose does the window auto-scroll serve?
Every time you open/close the door, it automatically scrolls down and up. What is the purpose of doing this? When the battery on my FR-S died and the auto scroll feature stopped working, there was absolutely no problem opening/closing the door without the auto scroll mechanism which makes me think it's a tad useless? As many people have mentioned already, the auto scroll is pinching the weather strip on many of our cars which is a nuisance. So is there a way to disable it or would this be a bad idea?
lupindub is offline   Reply With Quote
Old 08-27-2015, 01:40 PM   #2
strat61caster
strat61caster's Avatar
I'm surprised you didn't notice a difference, most people experience a popping as the window catches on the door frame with the autoscroll disabled (happens on frozen windows), it seats up inside a lip to reduce any chance of water/elements from getting in.
ineedyourdiddly
Old 08-27-2015, 01:47 PM   #3
Mike&Ike
Drives: Brz
It is to help release pressure when closing the door so it isn't hard to close.
Mike&Ike is offline   Reply With Quote
Old 08-27-2015, 02:01 PM   #4
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
hmm... still not a fan of window indexing - at least on this car (I've had the seal roll-up problem once).
PWBRZ is offline   Reply With Quote
Old 08-27-2015, 02:05 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
i sadly get both, when i open or close the door it sometimes makes a popping sound
when i roll the window up.. it makes a screeching sound
Old 08-27-2015, 02:48 PM   #6
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
There's a Technical Service Bulletin related to this- take your car into the dealership and tell them the windows screech in damp weather (typically when it happens) and they'll tear your doors apart and replace the guides with a different material at no charge.
FlamingRectumSyndrome is offline   Reply With Quote
Old 08-27-2015, 02:52 PM   #7
lupindub
Drives: Scion FR-S
Does this happen even when the windows are dry?
Old 08-27-2015, 02:57 PM   #8
WhiteFRS69
WhiteFRS69's Avatar
it doesnt do it when the window itself goes down or up,
it happens when i open or close the door, the very top squeaks
doesnt do anything when i roll the window down completely
Old 08-27-2015, 02:58 PM   #9
WhiteFRS69
WhiteFRS69's Avatar
only when the window is at the very top like when i open or close the window
Old 08-27-2015, 04:28 PM   #10
NOHOME
Drives: RAVEN
It is a useless function. If you live in a climate where it snows, it will eventually jam and leave your window down a bit on a snowy night.
I will never buy another car with this feature unless I move south. The only way I know to disable it leaves me without an interior light.
NOHOME is offline   Reply With Quote
Old 08-27-2015, 04:38 PM   #11
extrashaky
Drives: 2014 BRZ Limited
The people who bitch about window indexing are generally the same people who would bitch about the wind noise if the car did not have window indexing.
Some cars with this feature have the option to turn it off. I wonder if there is a switch in Techstream that will disable it.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
Bergen23 (08-29-2015), Silver Ignition (08-28-2015), strat61caster (08-27-2015)
Old 08-28-2015, 09:47 AM   #12
NOHOME
Drives: RAVEN
Wind noise is terrible in my car regardless.
Old 08-28-2015, 11:11 AM   #13
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Personally, I am thankful for the auto-scroll feature (maybe because mine has worked perfectly so far).
On my Nissan Xterra (which is also a tightly-made car - even after 15 years!) the doors can be very difficult to close without slamming. And on those occasions where a window is slightly lowered, my wife and I always accidentally slam the doors out of habit, to the point where it sounds like the window is about to shatter!
Fishbed77 is offline   Reply With Quote
Old 08-29-2015, 01:46 AM   #14
Tromatic
What did you expect for 25K? Refinement?
Tromatic is offline   Reply With Quote
Passenger's Auto Window Scroll Bonburner Issues | Warranty | Recalls / TSB 204 04-17-2018 07:34 PM
Auto window? gt3400 Cosmetic Modification (Interior/Exterior/Lighting) 7 03-05-2014 03:44 PM
Stop window auto scroll Rumbaar Cosmetic Modification (Interior/Exterior/Lighting) 10 08-27-2013 06:44 PM
Window scroll button flashing mashal Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 10:26 PM
What purpose or role will the FR-S / BRZ serve you? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 139 03-27-2012 02:28 PM
