Old 08-26-2015, 10:25 PM   #1
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Thumbs up Went for a long awaited drive tonight
I haven't posted about this on the forum, but June 29th my FA20 threw a rod bearing. After a month of my car sitting at the dealer, my warranty claim was denied and I had to pay over $2k for the teardown. Lesson of the day: if you're going to modify and drive the crap out of your car, either invest in cooling (oil cooler) or don't live anywhere it gets over 70 degrees....However, this wasn't going to be the end of Nightowl; After two weeks of searching, I was able to find an engine from a totaled 86 with 81 miles on it. Within a week, a pallet arrived with a basically new FA20 and me and two friends swapped it in overnight. Mind you, this swap happened 4 days before I had to return to college 3.5 hours away. It's been a long (and expensive) journey, but it's gratifying to know that I've been with this car since day 1, and didn't give up on her even when she ceased to run. It's roads like these that make me love this car every time I drive her, and I hope that everyone here finds their own way to love what they drive.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 09-02-2015, 12:58 AM   #2
Khánh
Khánh's Avatar
Drives: sc00ter
great job on the swap and sticking to the car!
Khánh is offline   Reply With Quote
Old 09-02-2015, 01:03 AM   #3
swarb
What mods did you have when you took it in the dealer? And what did they say?
Old 09-02-2015, 01:17 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
The twins are fine for hot weather though right? Only issue is cooling after mods like a s/c, no? Lately been hearing twins have issues with heat around here. I havent had issue. Drove for 6hrs round trip in 100-ish temps. No issue. (stock)
Nice to see your car running again. That must have been fun swapping an engine.
Packofcrows is offline   Reply With Quote
Old 09-02-2015, 01:32 AM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Oil cooler only matters for track days, not normal or Canyon driving.
Old 09-02-2015, 02:10 PM   #6
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
I too am curious as to what the dealer denied your warranty on...
BDotG is offline   Reply With Quote
Old 09-02-2015, 04:40 PM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I am also curious. What were the mods you had? Needing an oil cooler usually is for track days or forced induction.
Anyways glad to hear you're sticking with the car! Some true dedication to do a full engine swap in a day 4 hours before college.
Instagram: trevor.parque
Old 09-14-2015, 01:06 PM   #8
6-Shift
Señor Member
6-Shift's Avatar
had stock header on, stock tune, catless front pipe and catback. Flashing back to stock didn't matter because they were able to see that the ECU had been flashed 20+ times
The dealer basically told me that with the evidence of a tune, plus the physical evidence of rod discoloration and black box data, they wouldn't cover it because of "abuse."
Old 09-14-2015, 01:09 PM   #9
6-Shift
Señor Member
6-Shift's Avatar
Now that I've been monitoring oil temps, I'd honestly say no. Do you have an oil temp gauge/ Openflash tablet/ Torque app? Driving in traffic the oil temps stay around 210 or so which is normal. But, at any speed above 60 in 75+ degree ambient temps the oil temps climb to 220+. Start going 80+? You'll be pushing 230 degree oil temps. I can't even imagine what some guys are hitting on the track. After 230 degrees the car will start running richer to cool itself down, and at 235 degrees and higher you start running the risk of your oil breaking down and oil temps dropping dangerously low.
Old 09-14-2015, 01:13 PM   #10
6-Shift
Señor Member
6-Shift's Avatar
@MisterSheep @Packofcrows it depends completely on how you drive. If I'm just cruising along back roads (ozark mountain roads are like canyon roads, just with more tractors) my oil temps are fine. But if I'm really opening the car up and pushing it to 8/10ths or so, the oil temps will climb extremely quickly. After a 5 minute VERY spirited run at about 70 degree ambient temps, my oil hit 235 degrees....I'm running Eneos 0w-20, next spring I'm switching to 5w-30 to hopefully help with low oil pressures and heat.
Old 09-15-2015, 01:34 AM   #11
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Just curious, was that the only Toyota dealer in your area? A thrown rod shouldn't be the MAIN cause for denial of a factory warranty claim. If they were going to revert to the "flashed ECU" for denial, why did they need to tear it down?
Seems like you got gypped by the dealer. You should always be in contact with the customer line for the manufacturer any time your vehicle is at the dealer for warranty related repairs.
NARFALICIOUS is offline   Reply With Quote
Old 09-16-2015, 11:12 PM   #12
6-Shift
Señor Member
6-Shift's Avatar
If they had taken apart the engine and found the spun rod bearing with no other issues, it would've been approved. However, there was obvious discoloration on the piston rod, which indicated that this didn't exactly happen under "normal driving conditions." That's where the "signs of abuse" came from.
Old 09-17-2015, 12:32 AM   #13
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Glad you got the car back together. Details on those wheels? Painted? Plastidip? I like them.
As for the oil temp discussion, this may shed some light. I have gotten wayyyyy over 230 in the canyons.
http://www.ft86club.com/forums/showt...16#post2355616
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 09-21-2015, 10:23 PM   #14
6-Shift
Señor Member
6-Shift's Avatar
Wheels are Rustoleum Peel coat, same as plasti dip. Once I have the expendable income I'm getting them powdercoated basically the exact same color haha. Been on the car since mid july and still holding up great. Yeah if I've learned one thing it's that back when I had more expendable income I should've dropped the $600 for a decent oil cooler, it would've saved me almost $6k down the line
Better mileage after long drive jeepmor Scion FR-S / Toyota 86 GT86 General Forum 20 05-07-2015 06:57 PM
Tonight's FRS/BRZ meet in Long Beach ggpaul Southern California 3 08-27-2013 12:12 AM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
Test drive tonight! RearDrive Scion FR-S / Toyota 86 GT86 General Forum 3 06-03-2012 01:32 AM
