Drives: Blue BRZ
Start Button relocate??
Wondering if anyone has done a start button relocate from the centre console to the steering column? Any idea if there is any way to mount the button where the keyed ignition would normally be?
I had the centre console apart to day to fix a rattle and noticed that there doesn't seem to be anything more to the start button than just a button. The sensors for the key fob is completely separate. Moving the start button would allow a larger storage box to be put in the console and personally, I don't really care if people see that there's a button or not.... |
Senior Misanthrope
Jive Turkey moved his to the center trans tunnel area. Might be helpful.
http://www.ft86club.com/forums/showthread.php?t=41877 |
| The Following User Says Thank You to kch For This Useful Post: | funwheeldrive (02-26-2017) |
#3 | |
Drives: Ultramarine FR-S
#4 | |
Drives: Blue BRZ
I'll try and see how difficult it is to take off the ignition cover blank and see for myself. |
#5 | |
Or, to do it properly, you can turn the steering wheel half a turn left, take out the phillips screw on the left side, and repeat on the right side and pull the lower part of the column off completely. |
| The Following User Says Thank You to jonzhuxD For This Useful Post: | thunderlights (08-26-2015) |
Drives: 17 BRZ
did you ever end up doing this? interested for same reason
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I am in the process of doing it, I will post pictures when done.
But no, you can't put it on the steering column, there is no space at all |
| The Following User Says Thank You to tato.valverde For This Useful Post: | funwheeldrive (02-26-2017) |
Drives: 17 BRZ
#10 | |
Drives: 17 BRZ
Still there are probably better places to put it. I don't have seat warmers, maybe there. Where are you planning to put it tato.valverde? |
#11 | |
I'm going on vacation soon, so don't expect anything until 4 weeks from now |
#12 |
Drives: 17 BRZ
#13 |
| The Following User Says Thank You to tato.valverde For This Useful Post: | Harvie1031 (04-03-2017) |
#14 |
Drives: 2005 Toyota Camry
The primary reason why you can't do it is because a normal keyed ignition has both the steering column lock and the key/immobilizer in one assembly.
The push start has the steering column lock as one unit (the silver box as seen above) and the key/immobilizer as a second assembly. |
| Simple Start Button Help | Parappa | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 09-30-2014 12:56 PM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| Help disassembling the Start button | Skorov | DIY (Do-It-Yourself) Guides | 0 | 03-01-2013 12:14 AM |
| FS [SYD]: TRD Start Button | eleu2166 | Australia Classifieds | 3 | 11-04-2012 06:31 AM |
