Old 08-22-2015, 08:42 PM   #1
shellslinger
Drives: Whiteout FRS
Winmax W2 Brake Pads Sticking
Hey guys,
I was wondering if anyone can help me out with this issue. I just installed some Winmax W2 pads and it appears that they're sticking. The pistons were retracted and put back into their place and when I slid the caliper over the brake pads they were slid right in.
Any advice?
Thanks!
shellslinger is offline   Reply With Quote
Old 08-22-2015, 09:10 PM   #2
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
@WingsofWar didn't you have these pads at one point?
jimmillion is offline   Reply With Quote
Old 08-22-2015, 09:55 PM   #3
wparsons
wparsons's Avatar
What makes you think they're sticking? Were the pads easy to insert into the caliper carriers?
flickr
Old 08-22-2015, 10:04 PM   #4
shellslinger
Hello,
I have a pretty steep driveway and when I leave the car in neutral it'll roll back. However, when I installed the pads the car did not roll back.
I figured it out. I took off the shims and it now works perfectly.
Thanks all!
Old 08-23-2015, 11:41 PM   #5
Jeffsu350
Drives: Frs
Is it required to remove the shims? I just installed some winmaxx pads and left the shims. The car is still on jack stands as I still have some more work to do.
TIA
Jeffsu350 is offline   Reply With Quote
Old 08-24-2015, 01:19 AM   #6
shellslinger
TIA
I would leave off the shims. Although, my car is at 38k miles the brake pads had about 80% life on them. I compared the OEM pads with the Winmax pads and the Winmax pads are really thick, so with the shims it made the pads drag.
Old 08-24-2015, 01:21 AM   #7
TIA
No, but it may make the shims + pads "too thick", which will ersult in pad drag until it gets thin enough.
Old 08-24-2015, 01:24 AM   #8
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
@csgmike yeah winmax seems to have made then as absolutely thick as they could. Some people get lucky and it all fits new. Sometimes the shims only fit after a few miles.
Old 08-24-2015, 08:16 AM   #9
Jeffsu350
Drives: Frs
I think I misunderstand. I am talking about the anti-rattle "shims" that are on the side of the pads, not the backing plate.
Thanks CSG Mike! I finally got around to installing the pads I bought from counter space garage. I signed up for subiefest, as all the 86cup's left are really far from me.
I never reuse that backing plate.
Am I using the incorrect terminology?
Old 08-24-2015, 12:13 PM   #10
Ah, you can leave those in but it's a tight fit. That's normal
Where are you located? Everyone generally makes at least a 2 hour drive for most 86CUP events, with the Vegas guys regularly making a 5+ hour drive to make it...
Old 08-24-2015, 12:15 PM   #11
Jeffsu350
Drives: Frs
Yeah I know. I'm in San Diego.
I'm excited to try out the new pads and tires. Thanks again for all your great help and advice.
I'll post a review of the pads after my first session
Old 08-24-2015, 01:04 PM   #12
shellslinger
After bedding these brakes in, they feel great kinda like oem but they bite a little harder. Also not to mention without the backing plate and shims they look awesome on the car
Old 08-24-2015, 04:14 PM   #13
ryoma
ryoma's Avatar
you don't leave the backing plate on? I heard it is supposed to dissipate heat and protect the piston seals from melting. that's why I kept mine on, but I do agree the gold looks awesome lol
Old 08-24-2015, 07:11 PM   #14
shellslinger
Sorry about my post, I was referring to the two shims. Not the backing plate.
Winmax Brake Pads SOLD Lunatic Brakes, Suspension, Chassis 11 05-13-2015 11:00 AM
FS: Winmax W1 Stage 1 Brake Pads bobsacamenoh Brakes, Suspension, Chassis 6 04-26-2015 12:44 AM
My Review of Winmax Brake Pads ichitaka05 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-31-2014 12:11 AM
FS: Winmax W1 brake pads, front and rear, used, $120 retrosmiths Brakes, Suspension, Chassis 5 09-02-2014 12:32 PM
FS: Winmax brake pads new BeltedBiscuit Brakes, Suspension, Chassis 0 03-06-2014 02:24 AM
