Old 08-22-2015, 02:43 PM   #1
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
New to OFT. Basic question
I'm new to using the OFT and have a question about renaming the tunes.
My car is currently stock. I've downloaded the 2.06 OTS maps to my computer and figured out how to load the stage 1 bin files into the OFT. I have the 91 octane tune in slot 1 and the 93 in slot 2. On the OFT Bothe files have the same name and I would have to just remember which is which.
Can I simply rename the bin file on my computer prior to loading it in the OFT to give it a different name without causing any issues.
Thanks
RustySocket is offline   Reply With Quote
Old 08-22-2015, 03:00 PM   #2
raven1231
Yes you can
RustySocket (08-22-2015)
Old 08-22-2015, 03:02 PM   #3
RustySocket
Slow Learner
Drives: 15 Halo FRS
Appreciate the help
The Following User Says Thank You to RustySocket For This Useful Post:
raven1231 (08-22-2015)
Old 08-22-2015, 06:00 PM   #4
steve99
Thanks
see the oft tips link below for more info :-)
you can rename the files in openflash manager before you write them to oft
Old 08-22-2015, 06:06 PM   #5
RustySocket
Slow Learner
Drives: 15 Halo FRS
Im on tapatalk so cant see the link. Will have to check it out later. Thanks for the help
ECU LOGGING BRZ GT 86 FRS - what to look for the basic’s steve99 Software Tuning 59 12-15-2017 03:05 PM
BRZ Basic SQ Build hellyvin Electronics | Audio | NAV | Infotainment 13 07-22-2014 01:25 AM
toe, camber, castor? basic alignment question? rainmonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 05-18-2013 02:38 AM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 06:40 PM
